I have enable switcheroo in kernel config . Why is there not /sys/kernel/debug/vgaswitcheroo/switch ?
Linux ubuntu-raid-w500 2.6.38-10-generic #46-Ubuntu SMP Tue Jun 28 15:07:17 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
My computer is Thinkpad W500 . One graphic card is ATI Mobility FireGL V5700 (512 MB). The other one is Intel Graphics Media Accelerator 4500MHD .
I am using official kernel 2.6.38-10, I do NOT customize it. I add kernel option pcie_aspm=force in GRUB_CMDLINE_LINUX_DEFAULT of /etc/default/grub
Lekensteyn
  • 178,446
waterloo2005
  • 2,057
In Ubuntu 10.10 and up, vgaswitchheroo is already enabled so you don't need extra settings. And /sys/kernel/debug is already mounted, however you need root permissions to read the contents of /sys/kernel/debug, so using sudo su should work.
If there's still no switch, run lspci | grep VGA and make sure both cards are outputted. If one is missing a BIOS setting might be the cause, so check that.
Console example:
sergio@Sergio-L:~$ ls /sys/kernel/debug/vgaswitcheroo
ls: impossível aceder a /sys/kernel/debug/vgaswitcheroo: Permissão negada
sergio@Sergio-L:~$ sudo su
[sudo] password for sergio:
root@Sergio-L:/home/sergio#
root@Sergio-L:/home/sergio# ls /sys/kernel/debug/vgaswitcheroo/
switch
sergio91pt
  • 2,962
If you are not using the open-source radeon driver (or the nouveau driver in case of nvidia hardware), there won't be a /sys/kernel/debug/vgaswitcheroo/switch file. (ignoring hacks like asus-switcheroo and byo-switcheroo). Disabling KMS ("modeset=0") turns off this functionality too.
Even if the file exist, it cannot be reliable used when proprietary drivers (fglrx, nvidia) are loaded thereafter. You may experience lockups when trying to write commands to it. For vga_switcheroo on NVIDIA hardware, see also How to enable vga switcheroo on an Asus U41S?. For NVIDIA Optimus hardware in general, see Is a NVIDIA GeForce with Optimus Technology supported by Ubuntu?
Lekensteyn
  • 178,446
The answer in my case was buried above in a comment : there is a BIOS option on my HP laptop named "HybridGraphics" and it was set to "AUTO". This is seemingly not enough, and one has to set it to "ENABLE".
