Hope you guys are doing well. I want to ask one question to you guys. Please help me out.
I am using Macbook pro. I have a friend who is using Windows 7 but wants to switch to Ubuntu Operating system. He actually got bored of using windows. Now, I do not have any Ubuntu CD but I do have a USB device.
Can you please tell me guys how I can make my USB bootable and run the ubuntu on a windows computer? I want a complete guide please...
Thanks for your help. I really appreciate it.
Han
Get the proper architecture i.e 32-bit or 64-bit of the system.
then;
  1. Download Ubuntu Desktop
  2. Open the Terminal (in /Applications/Utilities/ or query Terminal in Spotlight).
  3. Run diskutil list to get the current list of devices.
  4. Insert your flash media.
  5. Run diskutil list again and determine the device node assigned to your flash media (e.g. /dev/disk2).
  6. Run diskutil unmountDisk /dev/diskN
    (replace N with the disk number from the last command; in the previous example, N would be 2).
  7. Execute sudo dd if=/path/to/downloaded.iso of=/dev/rdiskN bs=1m
    (replace /path/to/downloaded.iso with the path where the image file is located; for example, ./ubuntu.img or ./ubuntu.iso).
    • Using /dev/rdisk instead of /dev/disk may be faster
            <li>If you see the error dd: Invalid number '1m', you are using GNU dd. Use the same command but replace bs=1m with bs=1M</li>
            <li>If you see the error dd: /dev/diskN: Resource busy, make sure the disk is not in use. Start the 'Disk Utility.app' and unmount (don't eject) the drive</li>
         </ul>
  8. Run diskutil eject /dev/diskN and remove your flash media when the command completes.
  9. Restart your Mac and press alt/option key while the Mac is restarting to choose the USB stick.
Alternatively, Using UNetbootin
Download UNetbootin for mac
then;
Download Ubuntu Desktop (if you dont already have one)
After this, run UNetbootin select the ISO file, select a target drive (USB Drive or Hard Disk). After the installation, don't restart as prompted, since this is not for MAC but rather for windows. Just safely remove the USB and you can try it in a Windows PC if you have acess to any.
This link will lead you to a site with a free program to do a USB on your Mac and discusses the problem. http://www.makeuseof.com/tag/how-to-boot-a-linux-live-usb-stick-on-your-mac/ I'm not sure it is exactly what you need, give it a look.
Scott Porter
  • 268
  • 13
