63
I installed the CUDA 5.5 package on Ubuntu 14.04 (which is not supported for this version of Ubuntu version) , and I didn't do it well.
I want to remove what I've installed earlier and install a new CUDA 6.5 toolkit,
After typing this in the terminal: dpkg -l | grep -i nvidia,
I get the following output:
ii  bbswitch-dkms                                         0.8-1~trustyppa1                                    all          Interface for toggling the power on NVIDIA Optimus video cards
ii  bumblebee                                             3.2.1-90~trustyppa1                                 amd64        NVIDIA Optimus support
ii  bumblebee-nvidia                                      3.2.1-90~trustyppa1                                 amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  libcublas5.5:amd64                                    5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA BLAS runtime library
ii  libcuda1-331                                          331.38-0ubuntu7.1                                   amd64        NVIDIA CUDA runtime library
ii  libcudart5.5:amd64                                    5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA runtime library
ii  libcufft5.5:amd64                                     5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA FFT runtime library
ii  libcufftw5.5:amd64                                    5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA FFTW runtime library
ii  libcuinj64-5.5:amd64                                  5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA INJ runtime library (64-bit)
ii  libcurand5.5:amd64                                    5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA Random Numbers Generation runtime library
ii  libcusparse5.5:amd64                                  5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA Sparse Matrix runtime library
ii  libnppc5.5:amd64                                      5.5.22-3ubuntu1                                     amd64        NVIDIA Performance Primitives core runtime library
ii  libnppi5.5:amd64                                      5.5.22-3ubuntu1                                     amd64        NVIDIA Performance Primitives for image processing runtime library
ii  libnpps5.5:amd64                                      5.5.22-3ubuntu1                                     amd64        NVIDIA Performance Primitives for signal processing runtime library
ii  libnvtoolsext1:amd64                                  5.5.22-3ubuntu1                                     amd64        NVIDIA Tools Extension
ii  libnvvm2:amd64                                        5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA Compiler NVVM runtime library
ii  nvidia-331                                            331.38-0ubuntu7.1                                   amd64        NVIDIA binary driver - version 331.38
ii  nvidia-cuda-dev                                       5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA development files
ii  nvidia-cuda-doc                                       5.5.22-3ubuntu1                                     all          NVIDIA CUDA and OpenCL documentation
ii  nvidia-cuda-gdb                                       5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA GDB
ii  nvidia-cuda-toolkit                                   5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA toolkit
ii  nvidia-libopencl1-331                                 331.38-0ubuntu7.1                                   amd64        NVIDIA OpenCL Driver and ICD Loader library
ii  nvidia-nsight                                         5.5.22-3ubuntu1                                     amd64        NVIDIA Nsight Eclipse Edition
ii  nvidia-opencl-dev:amd64                               5.5.22-3ubuntu1                                     amd64        NVIDIA OpenCL development files
ii  nvidia-opencl-icd-331                                 331.38-0ubuntu7.1                                   amd64        NVIDIA OpenCL ICD
ii  nvidia-profiler                                       5.5.22-3ubuntu1                                      amd64        NVIDIA Profiler for CUDA and OpenCL
ii  nvidia-settings                                       331.20-0ubuntu8                                     amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-visual-profiler                                5.5.22-3ubuntu1                                     amd64        NVIDIA Visual Profiler
ii  primus
I'd like to remove only what is needed to install the newest CUDA toolkit. Packages, like bumblebee, I want to remain as they are.
Which packages should I remove and which should not be removed to get this done?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
tomtom
  • 781
9 Answers9
46
This method will give a complete removal of Cuda:
Simple
remove the CUDA files in /usr/local/cuda-5.0
Advanced
Uninstall just nvidia-cuda-toolkit
sudo apt-get remove nvidia-cuda-toolkit
Uninstall nvidia-cuda-toolkit and it's dependencies
sudo apt-get remove --auto-remove nvidia-cuda-toolkit
Purging config/data
sudo apt-get purge nvidia-cuda-toolkit or sudo apt-get purge --auto-remove nvidia-cuda-toolkit
Additionally, delete the /opt/cuda and ~/NVIDIA_GPU_Computing_SDK folders if they are present. and remove the export PATH=$PATH:/opt/cuda/bin and export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/cuda/lib:/opt/cuda/lib64 lines of the ~/.bash_profile file
33
For removing cuda, Nvidia has prepared a file (I presume this is a standard method). You need to change your directory to the cuda's path, which is by default /usr/local/cuda-x.y/bin; where x.y is your cuda version, you can do this by using the below command: (I have cuda 9.0=x.y)
 cd /usr/local/cuda-9.0/bin
There is a file named uninstall_cuda_9.0.pl in this directory (please note that the cuda version is 9.0, so run the uninstall_cuda_9.0.pl to remove cuda completely from your system!
chmod +x uninstall_cuda_9.0.pl
sudo ./uninstall_cuda_9.0.pl
As soon as you enter your password, the cuda files will be erased. (This may take a few minutes)
NOTE: How do you figure out which cuda has been installed on your Ubuntu system? By using the command nvcc, you can see that my cuda version is 9.0 in the last line of the nvcc result.
nvcc --version
The result will look like this:
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Sep__1_21:08:03_CDT_2017
Cuda compilation tools, release 9.0, V9.0.176
Note that the above method works if you set $PATH variable correctly, So if your nvcc command not works then please use the below command in terminal to find cuda version
ls /usr/local/ | grep cuda
UPDATE
I have installed cuda 10.2 on my system and it seems that there isn't uninstall_cuda_x.x.pl file, but nvidia replaced this file by cuda-uninstaller file in the same directory.
saeed masoomi
  • 431
Make sure the method you use to install cuda toolkit. This answer is for whom use deb files to install cuda. I have no idea if this works for .run files.
sudo apt-get autoremove --purge cuda
This can clear the cuda toolkit clearly. You can check that the folder /usr/local/cuda gone. And this command is the best choice to remove apt installed app.
But when you reinstall another version of cuda, you must use:
sudo apt-get install cuda-x.x
the version number must be included. I tried to install another version of cuda after the remove of the previous version, I find that sudo apt-get install cuda will still install the previous one.
13
For CUDA 10.1 or newer, try:
sudo /usr/local/cuda/bin/cuda-uninstaller
For CUDA 10.0, try:
sudo  /usr/local/cuda/bin/uninstall_cuda_10.0.pl
10
Try:
sudo apt-get --purge -y remove 'cuda*'
sudo apt-get --purge -y remove 'nvidia*'
sudo reboot
It removes any installed cuda and nvidia packages and then you can install any specific version that you like from: https://developer.nvidia.com/cuda-toolkit-archive.
One should NOT, unlike suggested in among others the accepted answer, manually remove files that were installed with apt (from some ppa, or nvidia repository).
The correct way to uninstall just cuda and keep your nvidia drivers would be:
sudo apt purge "libcublas*" "cuda-*" cuda
Possible, because they were installed as requirements, you can also purge,
sudo apt purge "nsight-*" nvidia-modprobe
After that you can, if you want, also remove the nvidia drivers with:
sudo apt purge "*nvidia*"
Of course, if you installed cuda using nvidia's .run file then this won't work; in that case you probably have some uninstall script.
Please refer the link below, which would help you decide whether your new installation and old installation of CUDA would be conflicting or not. If they aren't conflicting, you should be able to keep both of them.
If there is already a version of CUDA installed, you can do the following:
The method of uninstalling directly depends on the method of installation, whether it was a runfile, or a deb file, etc.
Use the following command to uninstall a Toolkit runfile installation:
$ sudo /usr/local/cuda-X.Y/bin/uninstall_cuda_X.Y.pl
Use the following command to uninstall a Driver runfile installation:
$ sudo /usr/bin/nvidia-uninstall
Use the following commands to uninstall a Deb installation:
$ sudo apt-get --purge remove <package_name>
Nvidia conflicting installations
aspiring1
  • 143
To remove packages without interruption (aggressive way) because there is no way others doing it.
PKG="something" ## in our case its Nvidia or/and CUDA
for item in `dpkg -i grep ${PGK} | awk '{print $2}'` ; do dpkg --remove --force-all $item ; done
It will remove the packages without any issues.
karel
  • 122,292
  • 133
  • 301
  • 332
In my case, I tried all of the above solutions but they did not work.
nvcc -V always returned version 11.7.
But I finally found that it was because my conda environment is activated.
After deactivating conda, the nvcc -V command does not work.
Silly experience, but sharing it in case anyone has the same problem.
