I have two users in my home folder: one is called "nico" (new username after release upgrade) and the other is called "nicolo" (old username).
In the "nico" folder there is small home picture, is seems to be the standard one and inside there are no contents in the single folders (Documents, Images, ect.). In the "nicolo" folder there are all my old datas.
How can I merge the two folders? Or at least just see and use the one with my old data as standard.
Thanks, Nico
EDIT: When I type ll /home I get:
total 40
   drwxr-xr-x  4 root root  4096 set 28 23:19 ./
   drwxr-xr-x 24 root root  4096 set 29 08:25 ../
   drwxr-xr-x 23 nico nico  4096 set 29 10:09 nico/
   drwxr-xr-x 58 nico nico 24576 set 27 13:52 nicolo/
Use rsync to sync the two directories:
rsync -aP /home/nicolo/ /home/nico
Once you're satisfied that all the data is now available in your new home directory, feel free to delete the old one (rsync has an option to delete files after copying, but still...). Also note the / after nicolo - it's needed to make rsync sync the directories instead of making a nicolo directory inside nico.
muru
  • 207,228
