We have developed an application in Visual Basic 6 as a front end. This application requires to capture automation values from machinery to system. It captures the data using serial port.
So here I would like to know first, will Ubuntu supports installing vb6 in it?
If that's the case, what is the process to install and execute an application that need to be installed on Ubuntu.
galoget
  • 3,023
murali raju
You can install Visual Basic 6 with wine. For installing wine you just have to deploy the setup as you do in Windows and install. Then you can find the software in /home/.wine/drive_c/Program Files folder. You can check this link to get more information of wine.
galoget
  • 3,023
