I've installed Netbeans 8.0 on Ubuntu 12.04. After that I updated the operating system and now the Ubuntu version is 14.04.
Netbeans was installed in the default folder. I did not specify any custom folder for installation.
Netbeans asked to install updates, but was unable to continue the operation, because Netbeans was not running under root permissions.
How can I start Netbeans with root permissions?
What sudo command should be executed in terminal to launch Netbeans as root?
I searched this in Google but did not find a working answer.
It's not advised to use sudo against graphical applications, try to run it with gksu:
gksu netbeans
Or if the executable is not systemwide, cd to where it is located and:
gksu ./netbeans
