I am trying to use an Omnikey 6121 smartcard reader with an OpenPGPv2 smart card. The reader is recognized, as I see from gpg --card-status and I was able to edit some card details like URL, name etc
However, when I try to issue a "keytocard" command, I get the following:
gpg: writing new key
gpg: 3 Admin PIN attempts remaining before card is permanently locked
Please enter the Admin PIN
gpg: ccid_transceive failed: (0x10002)
gpg: apdu_send_simple(0) failed: invalid value
gpg: failed to store the key: invalid argument
gpg: error writing key to card: invalid argument
Same error with --debug-ccid-driver.
And similarly, if I just issue a "generate":
gpg/card> generate
Make off-card backup of encryption key? (Y/n) n
Please enter the PIN
What keysize do you want for the Signature key? (2048)
What keysize do you want for the Encryption key? (2048)
What keysize do you want for the Authentication key? (2048)
Please specify how long the key should be valid.
         0 = key does not expire
      <n>  = key expires in n days
      <n>w = key expires in n weeks
      <n>m = key expires in n months
      <n>y = key expires in n years
Key is valid for? (0)
Key does not expire at all
Is this correct? (y/N) y
You need a user ID to identify your key; the software constructs the user ID
from the Real Name, Comment and E-mail Address in this form:
    "Heinrich Heine (Der Dichter) <heinrichh@duesseldorf.de>"
Real name: Deim0s Anomaly
E-mail address: deim0s@example.com
Comment:
You selected this USER-ID:
    "Deim0s Anomaly <deim0s@example.com>"
Change (N)ame, (C)omment, (E)-mail or (O)kay/(Q)uit? O
gpg: generating new key
gpg: please wait while key is being generated ...
gpg: generating key failed
gpg: key generation failed: general error
Key generation failed: general error
gpg/card>
what's going on? Can somebody please help?
Deim0s
  • 139
Weird, but I finally managed to make this setup work (Omnikey 6121 + OpenGPG v2 card). This is how a mere mortal can achieve the same:
  1. Disable 90gpg-agent-mine and 90ssh-agent-mine in /etc/X11/Xsession.d/ so that they won't try to start gpg-agent or ssh-agent
  2. Create a new gpg-agent-wrapper like explained in https://blog.flameeyes.eu/2010/08/smart-cards-and-secret-agents
In (1), the reason to not start gpg-agent from there is that it will not enable --enable-ssh-support, which is something I wanted.
By issuing a gpg --card-status, you will now notice a small delay and then:
gpg: detected reader `OMNIKEY CardMan (076B:6622) 6121 00 00'
Application ID ...: ......
That means card now also will work for writing operations! Yay! And my keytocard was successful :)
Deim0s
  • 139
