I have been trying to install gnome3 to my ubuntu. And a had a partial success. At some point of installation, I came to an error, which I don't have any luck of solving, and I have searched for hours. The installation of gnome3 is now not that much of an issue, but of solving a dependency problem.
The problem is this: Every time I run an e.g. sudo apt-get install -f I get an error:
The following packages have unmet dependencies: libgtksourceview-3.0-1 : Depends: libgtksourceview-3.0-common (>= 3.10.2-0ubuntu1~saucy1) but 3.8.2-0ubuntu1 is installed E: Unmet dependencies. Try using -f.
when I run a apt-cache policy libgtk-3.0 I get:
libgtk-3-0-dbg:   Installed: (none)   Candidate:
3.10.7-0ubuntu1~saucy1   Version table:
     3.10.7-0ubuntu1~saucy1 0
        500 http://ppa.launchpad.net/gnome3-team/gnome3/ubuntu/ saucy/main amd64 Packages
     3.10.6-0ubuntu2~saucy1 0
        500 http://ppa.launchpad.net/gnome3-team/gnome3-staging/ubuntu/ saucy/main amd64 Packages
     3.8.4-0ubuntu3 0
        500 http://rs.archive.ubuntu.com/ubuntu/ saucy/main amd64 Packages libgtk-3-0:   Installed: 3.10.7-0ubuntu1~saucy1   Candidate:
3.10.7-0ubuntu1~saucy1   Version table:  *** 3.10.7-0ubuntu1~saucy1 0
        100 /var/lib/dpkg/status
     3.8.4-0ubuntu3 0
I have tried removing libgtksourceview-3.0-common so I could install a new version, but I also get:
> sudo apt-get remove libgtksourceview-3.0-common
 libgtksourceview-3.0-1 : Depends: libgtksourceview-3.0-common (>= 3.10.2-0ubuntu1~saucy1) but it is not going to be installed
Does anybody have an idea how can I fix this dependency issue? This has happened on latest ubuntu 14.04 and also on earlier versions , like 13.10
Aleks
  • 412
  • 15
You have the GNOME3 PPAs (presumably added while you were using 13.10, and so still using the 13.10 tag). Update the PPA entries to use trusty instead of saucy, or remove the PPAs altogether:
sudo sed -i 's/saucy/trusty/g' /etc/apt/sources.list.d/*.list
sudo apt-get update
Note that if you do choose to remove the PPA, you will have to use ppa-purge, considering the extent of the effect the GNOME PPAs have.
muru
  • 207,228
