-1
The update fails with the following error messages:
bob@Proliant-Server:~$ sudo apt-get dist-upgrade
Reading package lists... Error!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_trusty-security_universe_i18n_Translation-en
E: The package lists or status file could not be parsed or opened.
I have run the following commands to no avail:
sudo apt-get clean
sudo apt-get update
I am getting desperate! Any suggestions would be appreciated! TIA
αғsнιη
  • 36,350
The answer suggested in the possible duplicate question mentioned above did work. Thank you.
These terminal commands solved my problem:
First remove the Merge List by opening a terminal (Press Ctrl+Alt+T to launch) and run this command:
sudo rm /var/lib/apt/lists/* -vf
Next, generate a new one by running a simple update:
sudo apt-get update
muru
  • 207,228
