Alright guys, here's the deal. I'm on ubuntu 14.04 xfce version, running on an Acer C270 Chromebook with crouton. This is a clean install of Ubuntu, not upgraded from a previous version, nor did it ever have any other version of wine on it.
I'm trying to install Wine. These are the commands I've used and all the solutions I've tried already to always the exact same result.
(trusty)pineapplez13@localhost:~$ sudo add-apt-repository ppa:ubuntu-wine/ppa
To success of adding the wine ppa
(trusty)pineapplez13@localhost:~$ sudo apt-get update
Also successful
(trusty)pineapplez13@localhost:~$ sudo apt-get install wine
Reading package lists... Done
Building dependency tree
wine : Depends: wine1.6 but it is not going to be installed or
wine1.7 but it is not going to be installed
And this is the problem. It seems fairly common so I google and find several solutions. Installing only Wine1.7:
(trusty)pineapplez13@localhost:~$ sudo apt-get install wine1.7
wine1.7 : Depends: wine1.7-amd64 (= 1:1.7.26-0ubuntu1~ppa1) but it is not going to be installed
Depends: wine1.7-i386 (= 1:1.7.26-0ubuntu1~ppa1)
Recommends: cups-bsd
It would appear that I don't have i386 architecture right? So then I do this:
(trusty)pineapplez13@localhost:~$ sudo dpkg --add-architecture i386
That is all it outputs, so it would appear to be a success. So I do apt-get update. However installing wine1.7 again returns the same result.
So I try to install cups-bsd and it sends me on a dependency goose chase
(trusty)pineapplez13@localhost:~$ sudo apt-get install cups-bsd
cups-bsd : Depends: cups-client (= 1.7.2-0ubuntu1)
(trusty)pineapplez13@localhost:~$ sudo apt-get install cups-client
cups-client is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I also have tried installing wine1.7 and wine-i386 at the same time
(trusty)pineapplez13@localhost:~$ sudo apt-get install wine1.7 wine1.7-i386
wine1.7-i386:i386 : Depends: libglib2.0-0:i386 (>= 2.12.0) but it is not going to be installed
Depends: libglu1-mesa:i386 but it is not going to be installed or
libglu1:i386
Depends: libgphoto2-6:i386 (>= 2.5.2) but it is not going to be installed
Depends: libgphoto2-port10:i386 (>= 2.5.2) but it is not going to be installed
Depends: libgstreamer-plugins-base0.10-0:i386 (>= 0.10.22) but it is not going to be installed
Depends: libgstreamer0.10-0:i386 (>= 0.10.26) but it is not going to be installed
Depends: libldap-2.4-2:i386 (>= 2.4.7) but it is not going to be installed
Depends: libpulse0:i386 (>= 1:0.99.1) but it is not going to be installed
Depends: libxml2:i386 (>= 2.9.0) but it is not going to be installed
Recommends: libasound2-plugins:i386 but it is not going to be installed
Recommends: libcups2:i386 but it is not going to be installed
Recommends: libdbus-1-3:i386 but it is not going to be installed
Recommends: libfontconfig1:i386 but it is not going to be installed or
libfontconfig:i386
Recommends: libfreetype6:i386 but it is not going to be installed
Recommends: libgnutls26:i386 but it is not going to be installed
Recommends: libosmesa6:i386 but it is not going to be installed
Recommends: libsane:i386 but it is not going to be installed
Recommends: libtiff5:i386 but it is not going to be installed or
libtiff4:i386 but it is not installable
Recommends: libxslt1.1:i386 but it is not going to be installed
Recommends: libxt6:i386 but it is not going to be installed
Recommends: p11-kit-modules:i386 but it is not going to be installed
And here it is pointing to a bunch of libraries that I apparently don't have, also pointing back to an error with the dpkg multiarching so I also tried this fix:
(trusty)pineapplez13@localhost:~$ gksu gedit /etc/dpkg/dpkg.cfg.d/multiarch
Creating a text file with foreign-architecture i386 printed in it to allow me to install wine1.7-i386. After successfully updating apt-get I try to install wine1.7-i386 and I get:
(trusty)pineapplez13@localhost:~$ sudo apt-get install wine1.7-i386
libglu1:i386
libfontconfig:i386
Once again. Edit: I have confirmed that I do indeed have support for i386 architecture, because
sudo dpkg --print-foreign-architectures
Returns i386 so that appears not to be the problem, very strange.
Even using the -f command with apt-get doesn't change anything
(trusty)pineapplez13@localhost:~$ sudo apt-get install -f wine1.7
Also, using apt-get clean, apt-get autoclean, and apt-get -f install all return 0 packages modified in any way. Downloading through software center returns same result. I've tried what feels like every fix that has been uploaded as a solution to this problem but to no avail. This really doesn't wake any sense, I can't find out what the problem is.
Edit: I've now given up on installing wine, so I'm just going to try to build it in a 32-bit linux container. I'll post here with the steps I used if I ever get it working.
