I am having an issue with Ubuntu. I am running the latest version under Oracles VirtualBox. The highest resolution it will accept is 1600x1200.
I have a new Samsung 28" UHD 4k display. I need to run this in fullscreen. So I would like to at least get 1080p out of it.
Are there any workarounds?
Also, I have 3d acceleration enabled but when I move my cursor it is very laggy, spikes so to speak.
Thanks kindly.
1: Video Memory
I got a message saying that my gues needed at least 33MB (or something) of video memory. I set it to 64MB and I could select my full 4K resolution.
2: Scaling factor
Not relevant to Ubuntu most likely, but just adding it here in case someone stumbles on this post from Google
Something else that may be affecting this is the scaling factor in Windows 10.
If this is set to 150% your guest resolution will also be scaled and you won't be able to select the full 4K resolution in the client causing everything to look slightly blurry.
You can set this to back 100%, which will make everything work as expected again.
Or if you want to keep the 150% scaling in Windows but not your guest, you can check out this post. (setting guest resolution through command line)
Haven't tried that myself though.
I'm going to ask the obvious, but have you install the VBoxAdditions?
On the main menu if you click
Devices -> Install Guest Additions CD Image
It may or may not auto prompt the install, but after it should work.
My build is current running at 3840x2009 (not 2160 because of my main OS menu bar and the VM wrapped borders)
Hope this helps!
Min
  • 131
