I'm a Linux n00b, but it's something I'm really trying to learn.
Let's say I log in to my server at home directly and start a process. For the sake of specificity, it's a CraftBukkit Minecraft server. :)
There were some issues and now I want to restart the game server remotely. How can I log in and up that terminal session that is running the server?
I can access the computer through remote desktop. I can set up SSH if necessary.
Thanks!
Thomas Ward
  • 78,878
Jesse
  • 75
You cannot log remotely to a terminal that is already running on the machine.
Instead, use ssh to log to the system, it is installed by default on most distribution. Then, after login through ssh, you can kill the running server by using (let's say the executable is CraftBukkit)
> killall CraftBukkit
You can confirm the name of the running process to kill by looking at the process list shown by typing
> ps aux
Next, you can restart the server by calling the command line but add the "screen" command in front. Running the server inside a screen session enables you to always reconnect to the session from anywhere by doing
> screen CraftBukkit param1 param2 ...
// use CTRL-a then d to detach session
> screen -r // will reattach session
If screen is not available on the system install it with
sudo apt-get install screen
jmbouffard
  • 1,085
