How do you check if a property is undefined in qml?
This is what I am trying to do:
Button {
text: if (text === "undefined"){"default text"}
Button {
Try:
text: text ? text : "default text"
"undefined" is just a string representation of a reference not referencing anything, just like None, or NULL in other languages.
=== is strict comparison operator, you might want to read this thread: https://stackoverflow.com/questions/523643/difference-between-and-in-javascript
import QtQuick 2.3
import QtQuick.Controls 1.2
Button {
This answer throws a warning for me.
QML Button: Binding loop detected for property "text"
Changing text to modelText instead throws an error.
ReferenceError: modelText is not defined
This stops the Javascript execution for me; i.e. the next line isn't called.
The same happens when setting it via Javascript, but is quite verbose.
import QtQuick 2.3
Button {
text: "default text"
Component.onCompleted: {
if (modelText !== "undefined") {
myButton.text = modelText;
typeofThe typeof operator mutes the error and works as expected.
import QtQuick 2.3
Button {
if (typeof modelText !== "undefined") {
To compare with undefined you write text === undefined. This will evaluate to false if text is null.
If you want check if value is present (i.e., check for both undefined and null), use it as condition in if statement or ternary operator. If you need to store result of comparison as a boolean value, use var textPresent = !!text (though double ! might appear confusing to one reading the code).
Since no one has mentioned it, since Qt 5.15, you can also use the nullish-coalescing operator ?? operator to catch both undefined and null:
Button {
text: text ?? "default text"
If you want to be very explicit, QML allows us to bind to multiline expressions like so:
Button {
text: {
if (text == null) {
return "default text"
return text
Note: The use of == null also works for undefined.
