I'm trying to fix an almost full boot partition, but can't seem to get any apt-get action to run. Not sure how to fix this messy situation.
# apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 libssl-dev : Depends: libssl1.0.0 (= 1.0.1-4ubuntu5.14) but 1.0.1-4ubuntu5.17 is installed
E: Unmet dependencies. Try using -f.
# apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
  libssl-dev
The following packages will be upgraded:
  libssl-dev
1 upgraded, 0 newly installed, 0 to remove and 111 not upgraded.
1 not fully installed or removed.
Need to get 0 B/1,574 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
Do you want to continue [Y/n]?
dpkg: dependency problems prevent configuration of libssl-dev:
 libssl-dev depends on libssl1.0.0 (= 1.0.1-4ubuntu5.14); however:
  Version of libssl1.0.0 on system is 1.0.1-4ubuntu5.17.
dpkg: error processing libssl-dev (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
 libssl-dev
# df -h
Filesystem                  Size  Used Avail Use% Mounted on
/dev/mapper/DRAGONITE-root   61G  3.7G   55G   7% /
udev                        993M   12K  993M   1% /dev
tmpfs                       201M  296K  201M   1% /run
none                        5.0M     0  5.0M   0% /run/lock
none                       1002M     0 1002M   0% /run/shm
/dev/vda1                   228M  163M   53M  76% /boot
# apt-get -f autoremove
  libssl-dev
  libssl-dev
 libssl-dev
Update:
Ran the following with error:
# sudo apt-get purge libssl-dev
You might want to run 'apt-get -f install' to correct these:
 php5-dev : Depends: libssl-dev but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
alphadogg
  • 115
Run the following commands to fix the problem:
sudo apt-get update
Take note of what packages are to be uninstalled. If the output lists 13 packages to uninstall, you can re-install everything using the following command. Otherwise, copy and paste each line, one-by-one after this command to reinstall everything.
sudo apt-get install --reinstall libroot-core-dev libssl1.0.0 libssl-dev
Again, that command will reinstall all 13 packages.
I don't know your situation but it may be wise to run the command:
sudo apt-get dist-upgrade
However, this command make changes to your system so you should refrain from that command until you have finished any important projects that may be affected by system changes!
mchid
  • 44,904
  • 102
  • 162
