I have an Ubuntu 14.04 machine which uses KVM to host a Windows guest. After a restart I am now unable to ping the Windows guest from the host machine, to confirm everything was working perfectly up until I restarted the host. I can ping the guest from every other PC on the LAN and the guest can communicate with the host without any problems. It is only the host that cannot talk to the guest.
This is the contents of /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
# The primary network interface
auto br0
iface br0 inet static
address 192.168.0.2
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
gateway 192.168.0.1
bridge_ports eth1
bridge_stp off
bridge_fs 0
bridge_maxwait 5
This is the output from ifconfig
br0 Link encap:Ethernet HWaddr 60:a4:4c:2c:81:1b
inet addr:192.168.0.2 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::62a4:4cff:fe2c:811b/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:897122 errors:0 dropped:0 overruns:0 frame:0
TX packets:770399 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:251836869 (251.8 MB) TX bytes:201878124 (201.8 MB)
eth1 Link encap:Ethernet HWaddr 60:a4:4c:2c:81:1b
RX packets:343226 errors:0 dropped:0 overruns:0 frame:0
TX packets:205432 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:100974693 (100.9 MB) TX bytes:43641794 (43.6 MB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:342809 errors:0 dropped:0 overruns:0 frame:0
TX packets:342809 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:750030721 (750.0 MB) TX bytes:750030721 (750.0 MB)
virbr0 Link encap:Ethernet HWaddr 06:6a:76:55:18:28
inet addr:192.168.122.1 Bcast:192.168.122.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
vnet0 Link encap:Ethernet HWaddr fe:54:00:b7:d7:c6
inet6 addr: fe80::fc54:ff:feb7:d7c6/64 Scope:Link
RX packets:90900 errors:0 dropped:0 overruns:0 frame:0
TX packets:94214 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:500
RX bytes:26204675 (26.2 MB) TX bytes:33808944 (33.8 MB)
Output from brctl show
bridge name bridge id STP enabled interfaces
br0 8000.60a44c2c811b no eth1
vnet0
virbr0 8000.000000000000 yes
The guest uses a bridge network to br0
UPDATE: After a bit more investigation it looks like it might be something to do with the bridge adapter
This is the output from arp -n
Address HWtype HWaddress Flags Mask Iface
192.168.0.69 ether 1c:3e:84:e6:65:cd C br0
192.168.0.128 ether e8:99:c4:a0:e8:f8 C br0
192.168.0.153 ether d0:27:88:47:02:02 C br0
192.168.0.1 ether 34:8a:ae:bf:c0:0e C br0
192.168.0.4 ether 52:54:00:b7:d7:c6 C br0
192.168.0.75 ether 52:54:00:98:e5:4c C br0
As you can see 192.168.0.4 which is the IP that I am trying to contact is on interface br0. 192.168.0.75 also belongs to the same machine and I cannot ping this either. All the other IPs are other machines on the network and I can ping those without any error
This is the output from ping
ping 192.168.0.4
PING 192.168.0.4 (192.168.0.4) 56(84) bytes of data.
There is no response from the ping ever. It stays as above with a blinking cursor forever
