I had a dual boot with Ubuntu 12.04 and Windows 7.
My update manager started to do weird things a while ago. It didn't get any new updates and it crashed a thousand times when I clicked on "upgrade now" to ubuntu 14. Then I always tried to report a bug from the dialog shown and it NEVER worked.
I had to upgrade so I could install some packages that only work on 13.10 and further. As I couldn't do it with the update manager, I tried with:
sudo apt-get update
sudo apt-get upgrade
After this I rebooted and that was it. Nothing works. I get a black background after the session starts (I had it configured to automatically start with my user). Network doesn't work, I get a "network disconnected" message as a welcome dialog so I can't use any online solutions.
USB ports are also broken, so I can't use another computer to download the solution.
Using a regular keyboard I ran a terminal and tried some of the solutions I found online, most of them need network connection or some sort of package download.
I didn't find any IOMMU options in my BIOS setup, doing some research I noticed my mother board is not on the list of compatible ones (it's an ASUS M5A87).
Then I tried:
sudo dpkg-reconfigure -a
It returned some errors that I couldnt catch, but the result is that everything is the same (or worse, I honestly don't know).
I also tried to run an older linux kernel to see if it works, but I get "failed to start session "ubuntu" " before and after the login menu (I get this message before and after I try to login).
I know there are a lot of details I am not giving, but I'm getting a bit desperate, I can't find answers for this problem and I wanted to start this question as soon as possible. Ask for any details that can help.
Of course, everything is working like a charm from windows 7, so no hardware issues here.
