I'm using Ubuntu 12.04 LTS and Skype 4.3 on my machine. I've taken a file named main.db from the location on my machine ~/.Skype/SKYPEUSERNAME/
Now I want to see the chat history from that file with each of the contact. For it I installed Sqliteman but I'm still not able to see the chatr history. Can someone please provide me the easiest though effective solution for this issue? Thanks in advance.
PHPLover
  • 1,807
Messages are stored as XML in messages table. You may use a simple SQL command to extract need dialog:
sqlite3 .Skype/yourusername/main.db "select timestamp,body_xml from messages where dialog_partner=\"partnerusername\";"
As you may use Sqliteman to run same command:
select timestamp,body_xml from messages where dialog_partner="partnerusername";
user.dz
  • 49,176
