Hey guys so the other day my laptop updated to 8.1. After install it required a restart, i clicked yes and now its been stuck in an infinite preparing start up repair. So i installed ubuntu to USB booted from that in a hopes to access my windows partition through that and copy everything off. However every time I try access the drive it gives me "the NTFS partition is in an unsafe state please resume and shutdown windows fully"
I've tried running several sudo commands but none seem to be working!
any help appreciated.
the command being
sudo mkdir /mnt/new
sudo mount -t ntfs -3g -o remove_hiberfile /dev/sda1 /mnt/new
the error being
the NTFS partition is in an unsafe state. please resume and shutdown windows fully (no hibernation or fast restarting) or mount the volume read-only with the 'ro' mount option.
Jacob Vlijm
  • 85,475
actually its an issue with windows 8.1 that by default it goes to hibernation instead of shutting down. the solution for me was....
going to "Control panel" -> Power options -> check "show unavailable options" -> uncheck "FastBoot (recommended)" -> save and restart to ubuntu
that is due to hybrid shutdown in windows , If it is possible to go to recovery menu and restart it from cmd (restart not shutdown as shutdown leaves partitions unreadable ) you can try this on recovery cmd prompt
shutdown /s /f /t 0
also if that is not possible then from Ubuntu try to mount partition as read only so you can copy all your files
sudo mount -t ntfs -ro  /dev/sda /mnt/winpart
change /dev/sda and /mnt/winpart as per your specific details
