I'm trying to install glew and freeglut so I can program OpenGL. I have figured out how to fix my make all command but when I type make install I get this message:
Making install in src
make[1]: Entering directory `/home/connor/Documents/freeglut-2.8.1/src'
make[2]: Entering directory `/home/connor/Documents/freeglut-2.8.1/src'
 /bin/mkdir -p '/usr/local/lib'
 /bin/bash ../libtool   --mode=install /usr/bin/install -c   libglut.la '/usr/local  /lib'
libtool: install: /usr/bin/install -c .libs/libglut.so.3.9.0 /usr/local/lib/libglut.so.3.9.0
/usr/bin/install: cannot create regular file '/usr/local/lib/libglut.so.3.9.0': Permission denied
make[2]: *** [install-libLTLIBRARIES] Error 1
make[2]: Leaving directory `/home/connor/Documents/freeglut-2.8.1/src'
make[1]: *** [install-am] Error 2
make[1]: Leaving directory `/home/connor/Documents/freeglut-2.8.1/src'
make: *** [install-recursive] Error 1
How can I grant the permission?
muru
  • 207,228
You can install glew and freeglut without implementing difficult compilations. They are in Official Ubuntu Repository.
sudo apt-get install freeglut3 libglew1.10 glew-utils
Did you use sudo? So do sudo make ....
sudo stands for Super User DO. Be careful when using sudo because you can do a lot of damage, as you can run any command harmful or not.
muru
  • 207,228
cubecubed
  • 694
  • 25
