I'm trying to install sip for pyqt and trying to get checkinstall to work. But it keeps saying
    Installing Debian package... FAILED!
This is what's in the log file:
    (Reading database ... 191312 files and directories currently installed.)
    Preparing to unpack .../sip_4.16.3-1_amd64.deb ...
    Unpacking sip (4.16.3-1) ...
    dpkg: error processing archive /home/user/sip-4.16.3/sip_4.16.3-1_amd64.deb (--install):
    trying to overwrite '/usr/include/python2.7/sip.h', which is also in package python-sip-dev 4.15.5-1build1
    dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
    Errors were encountered while processing: /home/user/sip-4.16.3/sip_4.16.3-1_amd64.deb
Anyone know how I can fix this and get it to work? I can't find anything on what to do to fix this.. It looks like sip was installed successfully - as I can check the version number.
There also seems to be a deb file in the sip-4.16.3 folder. But when I try to install or remove, I get
    dpkg: error processing archive sip_4.16.3-1_amd64.deb (--install):
    Errors were encountered while processing: sip_4.16.3-1_amd64.deb
yob-v-u
  • 143
You already have SIP installed.
Your error message says that the file /usr/include/python2.7/sip.h already exists, and is part of the python-sip-dev file.
You can fix this in two ways:
  1. Uninstall python-sip-dev using sudo apt-get uninstall.
  2. Do nothing.
Kaz Wolfe
  • 34,680
