-1
Hi having problems with updating ubuntu 14.01
sudo apt-get update
Gives me the following.
E: Typen »!DOCTYPE« er ukendt på linje 1 i kildelisten /etc/apt/sources.list.d/playonlinux.list E: Listen med kilder kunne ikke læses.
Translated:
E: Type >>!DOCTYPE<< is unknown on line 1 in sourcelist /etc/apt/sources.listd/playonlinux.list E: list with sources couldn't be read.
After the >> in the code this symbol (<), without the () but if I write it in, the block disappears in here... (hope it makes sense)
I'm aware that it maybe would help to delete playonlinux, but my software-center won't open and I don't know any other way of deleting the program..
sudo rm playonlinux
doesn't work, don't know if I'm using the code correct..
Kind regards - The rook
Top Rookie
  • 45
You have an erroneous repo file. To fix it, type these commands:
sudo rm /etc/apt/sources.list.d/playonlinux.list
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys E0F72778C4676186
sudo wget http://deb.playonlinux.com/playonlinux_trusty.list -O /etc/apt/sources.list.d/playonlinux.list
sudo apt-get update
sudo apt-get install playonlinux
That's all.
Frantique
  • 8,673
Open your terminal and type as
sudo nano  /etc/apt/sources.listd/playonlinux.list
Then remove that error from line then save & exit.
Then try with
sudo apt-get update
else
as you already deleted playonlinux ,
sudo rm /etc/apt/sources.listd/playonlinux.list
Good luck.
Raja G
  • 105,327
  • 107
  • 262
  • 331
