I wished to run my steam with bumblebee but faced a problem: when I try to run steam using primusrun, I get segfault. Anything else also doesn't run with primus. Here's an example of running primusrun glxspheres64 with LIBGL_DEBUG=verbose.
shy@shy-Inspiron-N5110:~$ LIBGL_DEBUG=verbose primusrun glxspheres64
libGL: screen 0 does not appear to be DRI3 capable
libGL: screen 0 does not appear to be DRI2 capable
libGL: OpenDriver: trying /usr/lib/x86_64-linux-gnu/dri/tls/swrast_dri.so
libGL: OpenDriver: trying /usr/lib/x86_64-linux-gnu/dri/swrast_dri.so
libGL: driver does not expose __driDriverGetExtensions_swrast(): /usr/lib/x86_64-linux-gnu/dri/swrast_dri.so: undefined symbol: __driDriverGetExtensions_swrast
libGL: Can't open configuration file /home/shy/.drirc: No such file or directory.
libGL error: failed to load driver: swrast
Polygons in scene: 62464
Visual ID of window: 0x5f
Context is Direct
OpenGL Renderer: GeForce GT 525M/PCIe/SSE2
primus: fatal: failed to acquire direct rendering context for display thread
If I run steam using optirun, the steam itself works fine but when it comes to launching Dota, it gives me some other errors.
Launch options:
LD_PRELOAD=libpthread.so.0 libGL.so.1 __GL_THREADED_OPTIMIZATIONS=1 optirun %command%
Log itself:
Game update: AppID 570 "Dota 2", ProcID 10988, IP 0.0.0.0:0
ERROR: ld.so: object '/home/shy/.steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
/bin/sh: 1: libGL.so.1: not found
Game removed: AppID 570 "Dota 2", ProcID 10988
I tried to manually copy libGL.so.1 from my /usr/lib32/nvidia-343 to ~/steamlibs and use it instead. Now Dota gives me a segfault.
Game update: AppID 570 "Dota 2", ProcID 12567, IP 0.0.0.0:0
Segmentation fault (core dumped)
Game removed: AppID 570 "Dota 2", ProcID 12567
What am I doing wrong?
