11
I'm trying to compile Minetest 0.4.10 on Ubuntu 12.04.3 LTS with CMake, but I get this error:
andrew@rasts-tv:~$ cmake \Minetest-0.4.10
-- *** Will build version 0.4.10 ***
-- IRRLICHT_SOURCE_DIR =
-- IRRLICHT_INCLUDE_DIR = IRRLICHT_INCLUDE_DIR-NOTFOUND
-- IRRLICHT_LIBRARY = IRRLICHT_LIBRARY-NOTFOUND
-- Could NOT find IRRLICHT (missing:  IRRLICHT_LIBRARY IRRLICHT_INCLUDE_DIR)
-- CURL_INCLUDE_DIR = CURL_INCLUDE_DIR-NOTFOUND
-- CURL_LIBRARY = CURL_LIBRARY-NOTFOUND
-- CURL_DLL =
-- GetText disabled
CMake Error at /usr/share/cmake-2.8/Modules/FindX11.cmake:411 (MESSAGE):
  Could not find X11
Call Stack (most recent call first):
  src/CMakeLists.txt:147 (find_package)
-- Configuring incomplete, errors occurred!
I installed LXDE (Lightweight X11 Desktop Environment), but it still shows the same error. What should I do?
This is the error message I got after installing the x11 header files:
-- CURL_DLL =
-- GetText disabled
CMake Error at /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:91(MESSAGE):
Could NOT find OpenGL (missing: OPENGL_gl_LIBRARY)
/usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:252(_FPHSA_FAILURE_MESSAGE)
/usr/share/cmake-2.8/Modules/FindOpenGL.cmake:153 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
src/CMakeLists.txt:148 (find_package)
muru
  • 207,228
LXDE and X11 are not quite the same thing. You probably need the X11 header files. Try installing libx11-dev:
sudo apt-get install libx11-dev
muru
  • 207,228
try running the command
sudo apt install xorg-dev
