Since ubuntu 14.04 LTS, i've been having this issue that my wireless connection gets "messed up" - more specifically I sometimes loose connection.
I'm currently solving this issue by disconnecting and then connecting back again. This works either by me clicking the top right unity bar icon, or by issuing an rfkill block wifi followed by an rfkill unblock wifi command
I haven't found a solution to the read problem yet, but I got this idea that if i could programatically handle this situation with a script that triggers when the disconnect occurs, i'll be just fine.
I also don't want to create a script that constantl polls for the wifi status, I'd want to listen for this specific event, and act uopn being notified.
Is this somehow possible?
First of all:
What you describe as your desired answer is what you actually call: I also don't want to create a script that constantl polls. Inotify also is used in a constant loop to "listen" to changes in the current state. In other words: the other option you assume to exist does not exist without some kind of a loop.
I also think your image of a loop is too heavy. On every system, in every application there are numerous loops active to wait for triggers. It should have no noticable effect on your resources.
The "anatomy" of such a take-action-on-event mechanism is basically:
in a while loop:
check the current status;
if a is True:
    take action A
if a is False:
    do nothing
wait a few seconds
In a bash script
Integrating this script (to check your connection) in a while loop (with a few minor changes) should do what you describe: re-establish your connection and send a notification.
#!/bin/bash
while :
do
  wget -q --tries=10 --timeout=20 --spider http://google.com
  if [[ $? -eq 0 ]]; then
  else
          rfkill block wifi
          rfkill unblock wifi
          notify-send "connection re-established"
  fi
  sleep 4
done
In a python script
The function check() returns True or False. If True (connection is up), nothing happens. If False, your rfkill block wifi / rfkill ublock wifi is executed.
#!/usr/bin/env python3
import socket
import time
import subprocess
def check():
    try:
        host = socket.gethostbyname("www.google.com")
        s = socket.create_connection((host, 80), 2)
        return True
    except Exception:
        return False
while True:
    if check() == True:
        pass
    else:
        subprocess.call(["/bin/bash", "-c", "rfkill", "block", "wifi"])
        subprocess.call(["/bin/bash", "-c", "rfkill", "unblock", "wifi"])
        subprocess.Popen(["/bin/bash", "-c", "notify-send 'conncection re-established'"])
    time.sleep(4)
Jacob Vlijm
  • 85,475
My script for handling FREE WIFI login/logout and WIRELESS connection reconnect and repair.
It connects to free wifi, logs in, gets connection time left and waits until time is up and checks wifi and login status and internet connection, logs out and repeats.
For sending notifications to desktop enviroment use
notify-send "YOUR MESSAGE HERE"
Wifi connection repair is handled in function ReConnect()
#!/bin/bash
WIFI_DEVICE="wlp3s2"
USER_PC="T-00%3AC0%3AA8%3AC7%3AF0%3AF1"
USER_USB="T-00%3AE0%3A4C%3A84%3AD2%3A5C"
USER_NAME="$USER_PC"
LOGIN_URL="http://starse.hotspot/login?username="
LOGOUT_URL="http://starse.hotspot/logout"
STATUS_URL="http://starse.hotspot/status"
WIFI_NETWORK="starse.WiFiPoint"
WIFI_PROFILE_FILE_SEARCH="starse"
PORT=5555
LOGIN_RETRY=5
REPEAT_HOURS=10000
SECONDS_LEFT="0"
ONE_MINUTE=15
MINUTES=0
START=0
END=0
ONE=1
ZERO=0
function CleanConnections()
    MYDIR=$(pwd)
    #remove all connections from network manager
    cd /etc/NetworkManager/system-connections/ &> /dev/null
    rm "$WIFI_PROFILE_FILE_SEARCH.*" &> /dev/null
    cd $MYDIR &> /dev/null
    # check if WIFI_DEVICE is connected to WIFI_NETWORK
    WIFI_OK=$(iwconfig $WIFI_DEVICE | grep -c $WIFI_NETWORK)
    # while not connected, try to repair connection
    while [ $WIFI_OK = "0" ]
    do
        # check if wifi radio is on / turn it on
        RADIO=$(nmcli radio wifi)
        sleep 1
        if [ "$RADIO" = "onemogočeno" ]
        then
            nmcli radio wifi on
            echo "$(date), WIFI RADIO OMOGOČEN!"
        fi
        sleep 1
        # check if WIFI_DEVICE is connected to WIFI_NETWORK again
        if [ $WIFI_OK = "0" ]
        then
            # if not connected, connect to WIFI_NETWORK
            echo "$(date), POVEZAVA WIFI PREKINJENA!"
            nmcli d wifi connect "$WIFI_NETWORK" &> /dev/null
            sleep 1
            sleep 1
            # if connection is still not established, restart network-manager and check connection
            then
                service network-manager restart
                sleep 2
                echo "$(date), NETWORK MANAGER PONOVNO ZAGNAN!"
            else
                echo "$(date), POVEZAVA WIFI VZPOSTAVLJENA!"
                sleep 2
            fi
        fi
    done
function Login()
    RETRY_COUNT=0
    LOGIN_OK=0
    # while not logged in
    while [ $LOGIN_OK = "0" ]
    do
        # try to login
        LOGIN_OK=$(curl -s -m 2 "$LOGIN_URL$USER_NAME" | grep -c "You are logged in")
        if [ $LOGIN_OK = "1" ]
        then
            echo "$(date), PRIJAVA USPEŠNA."
            break
        else
            # if could not login, try for RETRY_COUN
            echo "$(date), PRIJAVA NEUSPEŠNA! Ponavljam $RETRY_COUNT od $LOGIN_RETRY"
            RETRY_COUNT=$((RETRY_COUNT+1))
            sleep 1
        fi
        # if RETRY_COUNT expired then ReConnect and continue
        if [ $RETRY_COUNT -gt $LOGIN_RETRY ]
        then
            ReConnect
            RETRY_COUNT=0
            continue
        fi
    done
function GetSecondsLeft()
    STATUS_PAGE=$(wget -T 2 -q -O - "$@" "$STATUS_URL")
    sleep 10
    MIN1=$(echo $STATUS_PAGE | grep -o '[0-9| ][0-9]m' | tail -1 | tr -d 'm' | tr -d ' ')
    sleep 1
    SEC1=$((MIN1*60))
    echo "$(date), ČAS PRIDOBLJEN. NA VOLJO: $((SEC1))s"
    eval "$1"="$SEC1"
#ReConnect
LOGIN_NR=1
while  [ "$LOGIN_NR" -lt "$REPEAT_HOURS" ]
do
    # try to login first
    Login
    #set counters
    START=$(date +%s)
    # get time left from status page
    GetSecondsLeft SECONDS_LEFT
    # clean wifi profiles dir
    CleanConnections
    # get first ELPASED_SEC
    END=$(date +%s)
    ELPASED_SEC=$((END-START))
    # count till next login
    while [ $ELPASED_SEC -lt $SECONDS_LEFT ]
    do
        # display info
        echo "$(date), LOGIN: $LOGIN_NR, PRETEKLO: $((ELPASED_SEC))s,  NA VOLJO ŠE: $((SECONDS_LEFT-ELPASED_SEC))s"
        # wait ONE_MINUTE and periodicaly check for wifi and internet connection every two/three seconds
        ELPASED_MINUTE_SEC=0
        while [ $ELPASED_MINUTE_SEC -lt $ONE_MINUTE ]
        do
            # start timer
            S=$(date +%s)
            # check for wifi connection
            if [ $WIFI_OK = "1" ]
            then
                #  if wifi connection OK, check for internet connection
                PING="0"
                PING=$(ping -c 1 -w 2000 -s 1 www.google.si | grep -c "9 bytes")
                sleep 2
                if [ "$PING" = "0" ]
                then
                    echo "$(date), INTERNETNA POVEZAVA PREKINJENA! Vzpostavljam ..."
                    # if no internet connection then Login()
                    Login
                    # on reconnect caculate SECONDS_LEFT and reset ELPASED_SEC
                    ELPASED_SEC=0
                else
                    sleep 1
                fi
            else
                # if wifi connection is lost ReConnect()
                ReConnect
            fi
            # check if whole time is up and break
            END=$(date +%s)
            if [ $SECONDS_LEFT -le $ELPASED_SEC ]
            then
                break
            fi
            # add used seconds to ELPASED MINUTE
            E=$(date +%s)
            ELPASED_MINUTE_SEC=$((ELPASED_MINUTE_SEC+(E-S)))
        done
        END=$(date +%s)
    done
    # TIME IS UP
    # logout and increase LOGIN_NR
    curl -s -m 2 "$LOGOUT_URL" &> /dev/null
    LOGIN_NR=$((LOGIN_NR+1))
done
