-2
I had a dual boot installation ubuntu+windows that work just nice, but i messed up with ubuntu so much that i needed to reinstall it, and for some other reasons too, reinstallig was a good idea, so I did it. No I can not access windows because it does not shows up on grub. Already runned boot-repair but nothing. It seems that before reinstalling i should deleted the linux partition from windows and let the windows bootleader be the only one. How can I fix this problem? I've found pre installation instrunctions.
Thanks in advance.
Ubuntu 14.04
-- Edit --
Some details
Step 1. Be happy with ubuntu installed along side with windows
Step 2. Be bored so that I wanted to play arround ending up on screwing the ubuntu installation
Step 3. Care little about the installed OS and be so lazy to fix it so re install the ubuntu OS
Step 4. Finish installation all stuff required and notice that grub does not load your previous installation of windows (I didn't delete it.. just in case)
Step 5. Search the problem and found a lot of places saying that before re installing ubuntu you have to let windows be the boot loader so that ubuntu installation will detect it... (too late)
Step 6. Ask ubuntu :) (Solved by the way)
sudo fdisk -l
The out put of the command above, it is solved, but i have two entries for windows 8, would need another question maybe thought
Disco /dev/sda: 500.1 GB, 500107862016 bytes
255 cabezas, 63 sectores/pista, 60801 cilindros, 976773168 sectores en total
Unidades = sectores de 1 * 512 = 512 bytes
Tamaño de sector (lógico / físico): 512 bytes / 4096 bytes
Tamaño E/S (mínimo/óptimo): 4096 bytes / 4096 bytes
Identificador del disco: 0x9d5a16ba
Dispositivo Inicio    Comienzo      Fin      Bloques  Id  Sistema
/dev/sda1   *        2048      718847      358400    7  HPFS/NTFS/exFAT
/dev/sda2          720894   209717247   104498177    5  Extendida
La partición 2 no se inició en el limite físico del sector
/dev/sda3       209717248   976771071   383526912    7  HPFS/NTFS/exFAT
/dev/sda5          720896     4671487     1975296   82  Linux swap / Solaris
/dev/sda6         4673536   209717247   102521856   83  Linux
jaxkodex
  • 101
Run at Ubuntu's terminal:
sudo update-grub
...and your Windows installation will be on Grub's list again... :)
Read this official article from ubuntu. This might just be the fix you need.
