I recently installed nvidia-331 driver via Software & Updates -> Additional Drivers tab.
Now when I use:
sudo apt-get install <package>
or
sudo apt-get remove <package>
apt-get ends up with following errors:
lyn@antares:~$ sudo apt-get install hexedit
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  linux-image-generic
Use 'apt-get autoremove' to remove it.
The following NEW packages will be installed:
  hexedit
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/24.6 kB of archives.
After this operation, 88.1 kB of additional disk space will be used.
Selecting previously unselected package hexedit.
(Reading database ... 226032 files and directories currently installed.)
Preparing to unpack .../hexedit_1.2.13-1_amd64.deb ...
Unpacking hexedit (1.2.13-1) ...
Processing triggers for man-db (2.6.7.1-1) ...
Setting up nvidia-331 (331.89-0ubuntu1~xedgers14.04.2) ...
INFO:Enable nvidia-331
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
Traceback (most recent call last):
  File "/usr/bin/quirks-handler", line 65, in <module>
    operation_status = main(options)
  File "/usr/bin/quirks-handler", line 44, in main
    quirks = Quirks.quirkapplier.QuirkChecker(options.package_enable, path=quirks_path)
  File "/usr/lib/python3/dist-packages/Quirks/quirkapplier.py", line 38, in __init__
self._system_info = self.get_system_info()
  File "/usr/lib/python3/dist-packages/Quirks/quirkapplier.py", line 64, in get_system_info
return quirk_info.get_dmi_info()
  File "/usr/lib/python3/dist-packages/Quirks/quirkinfo.py", line 46, in get_dmi_info
'class', 'dmi', 'id', item)).read().strip()
  File "/usr/lib/python3.4/codecs.py", line 313, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xff in position 0: invalid start byte
dpkg: error processing package nvidia-331 (--configure):
 subprocess installed post-installation script returned error exit status 1
Setting up hexedit (1.2.13-1) ...
 nvidia-331
I already tried to remove nvidia drivers using this topic however apt-get still shows almost the same error.
A brutally way to remove the problem is the following
  1. edit the file /var/lib/dpkg/info/package-name.postrm; in this case it should be sudo gedit /var/lib/dpkg/info/nvidia-331.postrm
  2. adds exit 0 after the line #!bin/sh and save.
  3. run "sudo apt-get remove --purge nvidia-331". It should end without errors.
  4. make sure to delete the previously added line from the file (so again sudo gedit /var/lib/dpkg/info/package-name.postrm, remove the line and save).
  5. before trying anything else, run sudo apt-get update and sudo apt-get upgrade and check that it returns without errors.
tigerjack
  • 2,635
This worked for me :)
Make a backup and edit the file:
sudo cp /usr/bin/quirks-handler /usr/bin/quirks-handler.bak
sudo gedit /usr/bin/quirks-handler
replace the contents with the following code:
#! /usr/bin/python3
if __name__ == '__main__':
    pass
Purge nvidia-331:
sudo apt-get purge nvidia-331
It will complete successfully, and then you can restore the backup:
sudo mv /usr/bin/quirks-handler.bak /usr/bin/quirks-handler
kapcom01
  • 358
What worked for me was to purge nvidia-current, autoremove, restart, install cairo-dock then go to software updates and select the nvidia 331 from additional drivers (it took much more time than installing from cli), restart. Then from terminal install CCSM and activate the unity plug-in.
Now in commands what I think is the minimum to solve the issue:
  1. Before login (because lightdm shows the login) type ctrl+alt+F2
  2. From the CLI type sudo apt-get install cairo-dock
  3. Now typesudo apt-get install compizconfig-settings-manager
  4. Go back to the login typing ctrl+alt+F7
  5. select cairo as your shell (click in the Ubuntu icon) and login as normal
  6. From the application menu in Cairo go to system tools->preferences->CompizConfig Settings Manager
  7. Click OK in the warning dialog
  8. Click over desktop button in the left panel.
  9. Push the Ubuntu Unity Plugin button in the right panel
  10. Check the check box in the left panel to activate Ubuntu Unity Plugin
  11. Activate everything that is needed in order to get Unity back
  12. Voilá Unity is again working as before
I hope those steps make sense. the first explanation was a super fast story telling of what I had to do, so if the detailed minimum steps doesn't work for you then follow the exactly path I had to do
  1. Don't login typectrl+alt+F2, so you go to the CLI
  2. login and then type sudo apt-get install cairo-dock
  3. sudo apt-get purge nvidia-current and confirm
  4. Now type sudo apt-get autoremove and confirm
  5. sudo reboot
  6. Now login from lightDM (graphically) as usual but selecting the cairo shell from the Ubuntu icon
  7. If the GUI appears good jump to step 11; otherwise
  8. Go back to CLI typing ctrl+alt+F2
  9. type cairo-dock (I hope it starts correctly in your GUI; otherwise, you have to specify the DISPLAY before -gurus, please help-)
  10. Return to GUI typing ctrl+alt+F7
  11. From the applications menu in Cairo go to System Tools->Software Updates
  12. when it finished to update push the configuration button and go to the last tab (additional drivers)
  13. Other way is to go to System Tools->Preferences->Additional Drivers
  14. Select the best (tested) Nvidia driver and apply changes
  15. Restart using Cairo icon for that
  16. Then login again and install compizconfig-settings-manager using System tools->Administration->Ubuntu Software Center
  17. Continue from step 6 of the minimum steps (the previous list)
I hope this makes sense and work for you as it worked for me.
Mudit Kapil
  • 2,081
JQL
