I am on Ubuntu 14.04. 64-bit and I am trying to install linuxband. To do I need to install the package libjack-dev, but when I do so I obtain the following message:
Some packages could not be installed. This may mean that you have requested an
impossible situation or if you are using the unstable
libjack-dev : Depends: libjack0 (= 1:0.121.3+20120418git75e3e20b-2.1ubuntu1) but it is
not going to be installed
The point is that I do have the other libjack-jackd2 installed for example, but when I run the ./configure for linuxband I get:
checking for JACK_MIDI_NEEDS_NFRAMES... no
Which is the only no in the list. When I run the make, it generates a plethora of undefined references (examples:
src/main/c/linuxband-player.c: In function ‘main’:
src/main/c/linuxband-player.c:768:2: warning: ‘g_thread_init’ is deprecated (declared at
/usr/include/glib-2.0/glib/deprecated/gthread.h:261) [-Wdeprecated-declarations]
g_thread_init(NULL);
or later
linuxband-player.c:(.text+0x50b): undefined reference to `jack_transport_query'
linuxband-player.c:(.text+0x586): undefined reference to `jack_transport_query'
linuxband-player.c:(.text+0x5a1): undefined reference to `jack_last_frame_time'
linuxband-player.c:(.text+0x615): undefined reference to `jack_last_frame_time'
linuxband-player.c:(.text+0x672): undefined reference to `smf_peek_next_event'
linuxband-player.c:(.text+0x6b5): undefined reference to `smf_event_is_metadata
and so on)
until it ends in:
/tmp/ccrh0o5V.o:remote_control.c:(.text+0xf01): more undefined references to `g_log' follow
collect2: error: ld returned 1 exit status
make: *** [target/linuxband-player] Error 1
Can someone help please?
