I'm having problems with Unity on a slow laptop, but it's configured to autologin so I never see the login screen. Also, the screen or display driver is messed up so I don't see the far right part of the display.
I had already installed Lubuntu/LXDE earlier and I'd like to try logging into that instead -- but I can't get back to the login screen to set that as the desktop system for the user. The logout command gnome-session-quit doesn't work; I end up in the screen "the system is running in low-graphics mode".
The setting for a given user's desktop environment (Unity vs LXDE) is presumably in some text file somewhere. So if I could edit that file and then force a reboot, I'd achieve my goal. Help?
If you want to change the auto login behavior of lightdm edit /etc/lightdm/lightdm.conf using gksudo gedit /etc/lightdm/lightdm.conf
It should look something like this
[SeatDefaults]
autologin-guest=false
autologin-user=username
autologin-user-timeout=0
autologin-session=lightdm-autologin
greeter-session=unity-greeter
user-session=ubuntu
Comment all the line containing autologin. Next time you will get login screen.
If you are using Ubuntu 14.04 you may find this file empty, Simply add fillowing line in it
[SeatDefaults]
autologin-user=
Save and exit.
g_p
  • 19,034
  • 59
  • 69
