So I'm trying to get Ruby on Rails set-up on my development machine (with a fresh install of ubuntu 14.04).
Everything is going well until I get this lovely message from the terminal:
$ gem install rails
ERROR:  While executing gem ... (Gem::RemoteFetcher::FetchError)
    Errno::ECONNREFUSED: Connection refused - connect(2) for
 "your-dns-needs-immediate-attention.network" port 443
(https://your-dns-needs-immediate-attention.network/
quick/Marshal.4.8/rails-4.1.6.gemspec.rz)
After frantically Duck-Duck-Go-ing all over I found out a lot of people are having the issue.
Luckily, the awesome folks on SO have found this solution (See answer 2) but I've been trying for a while to get my resolv.conf file free of the offending line.
Since I can't overwrite the /etc/resolv.conf file, after inspecting the /etc/resolvconf/resolv.conf.d/ directory I only have the base and head files which leads me to believe that the actual contents of the file are being generated elsewhere.
Speaking of contents:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.1.1
search home.network
And the offending line is search home.network (according to the people who answered the above linked solution).
Question is, how do I remove this line of text in a persistent way? Is there some kind of magic option or flag to a command that will save the day?
It appears you have a Linux system.
But regardless if it's Windows, Ubuntu, or some other OS - here's the "workaround" until Comcast can get things to work.
Do NOT get your DNS servers dynamically from Comcast (which they'll give you 75.75.75.75 and 75.75.76.76) --
Rather, statically configure your DNS servers and use the two Google public DNS servers: 8.8.8.8 and 8.8.4.4
Not sure how Comcast got around this, but even when I had the Comcast servers and I tried to resolve using Google server on the nslookup command line nslookup www.yahoo.com 8.8.8.8 -- my results still came back in error with the 127.0.53.53 as the address. (Yet, I could ping www.yahoo.com and it would get the IP address properly).
However, I noticed when I VPN'ed into my office and was using my VPN connection to resolve hostnames, I would receive expected results.
Hence, I disabled my PC from using the automatically obtained DNS servers -- strapped the servers to Google -- and I'm getting expected results.
This article discusses Comcast's current challenges: http://domainincite.com/17401-comcast-users-report-name-collision-bugs
Kaz Wolfe
  • 34,680
Keith
