I installed php, mysql, phpmyadmin on my Ubuntu 12.04 localhost in the following steps:
I try these steps:
sudo apt-get install apache2
sudo /etc/init.d/apache2 restart
sudo apt-get install php5 libapache2-mod-php5
sudo apt-get install php5-cli
sudo apt-get install php5-cgi
sudo apt-get install php5-mysql
sudo apt-get install php5-pgsql
than after i faced phpmyadmin not found error and fixed using the following answer
How to solve the phpmyadmin not found issue after upgrading php and apache?
After applying that fix I got another error message:
Forbidden  You don't have permission to access /phpmyadmin on this server.
How can fix this?
Kamlesh Kumar
  • 271
6 Answers6
It solved :
sudo apt-get install mysql-server
sudo dpkg-reconfigure phpmyadmin
sudo service apache2 restart
Kamlesh Kumar
  • 271
You need to change the permission with:
sudo chown -R $USER:$USER /var/www/
sudo chmod -R 755 /var/www
Achu
  • 21,407
  1. You should check /etc/apache2 and find the below lines:
    <Directory /usr/share>
        AllowOverride None
        Require all granted
    </Directory>
  2. the apache2 config should have this line:
    Include /etc/phpmyadmin/apache.conf
  3. Be you you phpadmin config look like this:
    Alias /phpmyadmin /usr/share/phpmyadmin
    <Directory /usr/share/phpmyadmin>
        Options FollowSymLinks
        DirectoryIndex index.php
        <IfModule mod_php5.c>
            AddType application/x-httpd-php .php
            php_flag magic_quotes_gpc Off
            php_flag track_vars On
            php_flag register_globals Off
            php_admin_flag allow_url_fopen Off
            php_value include_path .
            php_admin_value upload_tmp_dir /var/lib/phpmyadmin/tmp
            php_admin_value open_basedir /usr/share/phpmyadmin/:/etc/phpmyadmin/:/var/lib/phpmyadmin/:/usr/share/php/php-gettext/:/usr/share/javascript/
       </IfModule>
    </Directory>
    <Directory /usr/share/phpmyadmin/setup>
        <IfModule mod_authn_file.c>
            AuthType Basic
            AuthName "phpMyAdmin Setup"
            AuthUserFile /etc/phpmyadmin/htpasswd.setup
        </IfModule>
        Require valid-user
    </Directory>
    <Directory /usr/share/phpmyadmin/libraries>
        Order Deny,Allow
        Deny from All
    </Directory>
    <Directory /usr/share/phpmyadmin/setup/lib>
        Order Deny,Allow
        Deny from All
    </Directory>
techraf
  • 3,316
The solution for me, was to uncomment the following lines:
AllowOverride None
Require all granted
</Directory>
in /etc/apache2/apache2.conf.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
I faced the issue when I installed PHPMyAdmin in Ubuntu OS 16.04. I fixed the issue by adding the line [Require all granted] in the Directory section.
Example:
<Directory /usr/share/phpMyAdmin/>
   AddDefaultCharset UTF-8
   <IfModule mod_authz_core.c>
     # Apache 2.4
     <RequireAny>
       #Require ip 127.0.0.1
       #Require ip ::1
       Require all granted
     </RequireAny>
   </IfModule>
   <IfModule !mod_authz_core.c>
     # Apache 2.2
     Order Deny,Allow
     Deny from All
     Allow from 127.0.0.1
     Allow from ::1
   </IfModule>
</Directory>
-1
This worked for me in centos removing unnecessary backup files of configuration
[root@Stats-Server-1 etc]# cd httpd/
[root@Stats-Server-1 httpd]# ls conf conf.d conf.modules.d logs modules run
[root@Stats-Server-1 httpd]# sudo nano conf.d
[root@Stats-Server-1 httpd]# cd conf.d
[root@Stats-Server-1 conf.d]# ls
autoindex.conf phpMyAdminbk.conf phpMyAdmin.conf.rpmsave userdir.conf php.conf phpMyAdmin.conf README welcome.conf
[root@Stats-Server-1 conf.d]# rm -rf phpMyAdminbk.conf
[root@Stats-Server-1 conf.d]# rm -rf phpMyAdmin.conf.rpmsave
[root@Stats-Server-1 conf.d]# sudo systemctl restart httpd.service
