Is there any way to save the Nautilus state? I'm usually opening more windows and more tabs, divided by arguments, but it's very frustrating to lose them every time I shutdown the system.
tigerjack
  • 2,635
There isn't a (simple) way to do this, but this question has a script that can help:
open nautilus as new tab in existing window
Note that xdotool and wmctrl need to be installed for it to work.
Using that script as a basis, you could make a script that automatically opens a defined set of windows and tabs. This is just to give a general idea and not tested. For example, I don't know how wmctrl would work with multiple Nautilus windows. I'm sure the loops/variables/quotes could be better too (I'm not attempting to simulate a 2D array yet).
windows=2
tabs1=(/home/user/Documents /home/user/Downloads)
tabs2=(/usr/share /etc)
#Save old clipboard value
oldclip="$(xclip -o -sel clip)"
#The following would be the cleanest way to code this:
#while i < $windows; do
    #open nautilus
    #for tab in tabs; do
        #open tab in this window
    #done
#done
nautilus ${tabs1[0]}
for tab in ${tabs1[@]}; do
    i=0
    for tab in ${tabs[@]}; do
        if [ $i -gt 0]; then
            echo -n tab | xclip -i -sel clip
            wmctrl -xF -R nautilus.Nautilus && xdotool key ctrl+t ctrl+l ctrl+v Return
        fi
        i=$[$i + 1]
    done
done
#Restore old clipboard value
echo -n "$oldclip" | xclip -i -sel clip
The best way to do this would be to loop through all windows and all tabs. It would open Nautilus with tab 1, then open tab 2, etc. It uses the clipboard to store the tab location, and pastes it in to the location field.
You would need to manually set the number of windows and the tabs in each one before each shutdown. But I realized you could use the script in reverse to save the open tabs:
wmctrl -xF -R nautilus.Nautilus && xdotool key ctrl+l ctrl+c
tab=$(xclip -o -sel clip)
tabs[0]=""
i=1
while [ "$tab" != "$tabs[0]"]; do
    tabs[i]="$tab"
    i=$[$i + 1]
done
#i=1
    #open window, open tabs?
#done
That's about all I can do at the moment. I may try to test this later, and any suggestions/fixes are welcome.
Nattgew
  • 2,139
In the case of windows, it's possible to make a custom launcher which opens all URIs specified.
You can see the file /usr/share/applications/nautilus-home.desktop. There is a line starting with Exec:
Exec=nautilus --new-window %U
You can change it in this way:
Exec=nautilus -n URI1 URI2 …
After you save it somewhere such as your desktop and check the executable permissions, it will open each specified URI in a separate window.
AliNajafies
  • 5,974
