Have run into an issue with an upgrade using Ubuntu14 on AWS. This seems different to such probs as full /boot and the like. How do I rectify this?
Setting up initramfs-tools (0.103ubuntu4.2) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-image-3.13.0-35-generic (3.13.0-35.62) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
The link /initrd.img is a dangling linkto /boot/initrd.img-3.13.0-35-generic
vmlinuz(/boot/vmlinuz-3.13.0-35-generic
) points to /boot/vmlinuz-3.13.0-35-generic
(/boot/vmlinuz-3.13.0-35-generic) -- doing nothing at /var/lib/dpkg/info/linux-image-3.13.0-35-generic.postinst line 491.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-35-generic /boot/vmlinuz-3.13.0-35-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-35-generic /boot/vmlinuz-3.13.0-35-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-35-generic
mktemp: failed to create file via template ‘/var/tmp/mkinitramfs-FW_XXXXXX’: No such file or directory
update-initramfs: failed for /boot/initrd.img-3.13.0-35-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.13.0-35-generic.postinst line 1025.
dpkg: error processing package linux-image-3.13.0-35-generic (--configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of linux-image-virtual:
linux-image-virtual depends on linux-image-3.13.0-35-generic; however:
Package linux-image-3.13.0-35-generic is not configured yet.
dpkg: error processing package linux-image-virtual (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Processing triggers for initramfs-tools (0.103ubuntu4.2) ...
update-initramfs: Generating /boot/initrd.img-3.13.0-29-generic
update-initramfs: failed for /boot/initrd.img-3.13.0-29-generic with 1.
dpkg: error processing package initramfs-tools (--configure):
subprocess installed post-installation script returned error exit status 1
linux-image-virtual
initramfs-tools
