I want to uninstall VMware Workstation 10.0.3 from my Ubuntu 14.04. I used the '.bundle' file to install VMware Workstation.
Open the terminal and run this command to uninstall VMware Workstation:
sudo vmware-installer -u vmware-workstation
Reference: VMware Workstation 10 Documentation Center: Uninstall Workstation from a Linux Host
- 122,292
- 133
- 301
- 332
You can try manual uninstall:
Prepend all commands with sudo, or switch to root using this command:
sudo su
Shut down all VMware applications and services.
/etc/init.d/vmware stop
Verify that all processes have stopped:
lsmod | grep vm
Note: A zero must be listed beside VMware related modules to indicate that they are no longer running.
Move the VMware libraries to the /tmp directory:
cd /lib/modules/kernel_version/misc
mv vm* /tmp
Note: If the kernel has ever been updated, you must check and move the files from multiple paths. Substitute the kernel version where indicated above.
Unload the kernel modules:
rmmod vmnet.o
rmmod vmmon.o
rmmod vmci.o
rmmod vmblock.o
rmmod vmppuser.o
Remove the VMware startup scripts:
rm /etc/rc2.d/*vmware*
rm /etc/rc3.d/*vmware*
rm /etc/rc5.d/*vmware*
rm /etc/rc6.d/*vmware*
Remove the remaining VMware files and directories:
rm -rf /etc/vmware*
rm /usr/bin/vmware-usbarbitrator
rm /usr/bin/vmnet*
rm -r /usr/lib/vmware*
rm -r /usr/share/doc/vmware*
Source: Manually uninstalling VMware Workstation from Linux hosts (38)
- 1,790
you can use the vmware-installer; already posted in here ->How to uninstall VMware Player?.
- 116
If you have installed .bundle packages, use below command to open again that installer. then the installer opens and checking if you have already installed this packages then installer list for you "unistall" or "remove" option to uninstall the package.
if your installation file located in home directory this command would be:
sudo ./yourbundleFileName.bundle
- 36,350
