You can open software center from a terminal by first opening a terminal and then typing the following command:
sudo software-center
The password prompt will be prompted from within the terminal instead of the desktop. You must use the password of the user that is logged into the desktop. This user must have sudo or admin privileges.
Also, I've never used "Landscape Service" but it sounds like that may be along the lines of something you are looking for as a management tool. - landscape.canonical.com
Wine allows Ubuntu and linux users to run microsoft programs.
To install MS adobe reader XI using wine and winetricks, follow these instructions.
Open a terminal and type the following commands:
sudo apt-get update
sudo apt-get install wine winetricks wine1.6* wine-gecko2.21* wine-mono0.0.8 ubuntu-restricted-extras ttf-mscorefonts-installer
You might not need all of those but installing all of those will give you what you need.
After installing wine, run this command:
winetricks -q mspatcha
Then, download Adobe Reader XI from here extract the .exe and right-click on the "setup.exe" file in the extracted folder. Choose to open the file using "wine windows program loader". Follow the instructions and agree to accept the user agreement to install Adobe Reader.
Next, download the FileOpen plugin installer from here. All you have to do is right click on the installer and choose to open the file using "wine windows program loader". Follow the prompts to install.
One last note. Adobe reader opens without protection mode or something like that so take note if you feel there is some sort of a security risk running certain pdf files.
Also, There's a 30 day free trial available for Adobe Acrobat but you must install AIR first as it is required. AIR is available here (click "download for another computer" and select windows operating system) download the .exe and run it with wine to install. Adobe Acrobat is available here(you will have to login or register to download). Open a terminal to first install some dependencies with the following two commands:
sudo apt-get install winbind
winetricks atmlib
Again, download the .exe, open it with wine, and follow the prompts to install. If you encounter problems, open a terminal and install the file by typing wine followed by space followed by the path to the .exe file (it is usually possible to drag and drop the file into the terminal to automatically fill in the path for you). Any errors will appear in the terminal during the installation along with suggestions and information on how to fix the issue.
More info: winehq.org
and
fileopen.com
