-1
how do i create a slideshow in GIMP image editor using jpeg images saved in a folder and use it as wallpaper in Ubuntu 12.04 LTS version? The slideshow has to be timed so that the wallpaper keeps changing at fixed time interval, and background music is also present..
Rinzwind
  • 309,379
bristi
You don't actually need Gimp to do this thing. There are several methods to set multiple images as your desktop wallpaper and change periodically. Here I am explaining a method which does not require installation of any new packages.
First Goto Programs and open Shotwell. It comes pre-installed with Ubuntu. Now You can see the images in your Library. You can import as much as images you want. After doing this select the images you want to set as you wallpaper.
And then goto File->Set as Desktop Slideshow
Adjust your time delay. Done!!
Anandu M Das
  • 2,303
