Ubuntu 14.04 - installed apt-get install openssh-server, username is sun and password is 1234 and root also has password 1234.
Remotely connecting and failing to allow me.
suns-MacBook-Air:js sun$ ssh sun@192.168.1.6
sun@192.168.1.6's password:
Permission denied, please try again.
Permission denied (publickey,password).
suns-MacBook-Air:js sun$ ssh root@192.168.1.6
root@192.168.1.6's password:
EDIT: PC is using ipv4 and ipv6
$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether d4:be:d9:fd:84:fe brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.6/24 brd 192.168.1.255 scope global eth0
    inet6 2a02:a03f:24af:bd00:898f:6294:6b5e:94f6/64 scope global temporary dynamic
       valid_lft 345642sec preferred_lft 85306sec
    inet6 2a02:a03f:24af:bd00:d6be:d9ff:fefd:84fe/64 scope global dynamic
       valid_lft 345642sec preferred_lft 345642sec
    inet6 fe80::d6be:d9ff:fefd:84fe/64 scope link
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 1c:3e:84:01:bf:86 brd ff:ff:ff:ff:ff:ff
Oli
  • 299,380
Edit: I skipped right to the end of the question and hadn't noticed you were trying to log in with a normal user account to begin with. The following explains why remote root login doesn't work by default in Ubuntu. Either way, it seems to have helped.
For the normal user stuff, just look in /var/log/auth.log. It'll tell you exactly what the problem is and that should give you a fairly decent idea of what you need to do.
But for root issues, there's a little block in /etc/ssh/sshd_config.
# Authentication:
LoginGraceTime 120
PermitRootLogin without-password
StrictModes yes
That's the default and it means it'll only allow SSH key based authentication for root.
It won't allow you to log in with a password.
Obviously you could change the setting to yes but you're starting to unravel the security of Ubuntu. Having a working root login (especially with a super-crackable password) is usually a pretty awful (and unnecessary) idea. It would be easier to just use a SSH key.
Oli
  • 299,380
