sudo apt-get remove --purge fglrx*
Reading package lists... Done
Building dependency tree
E: Unable to locate package fglrx-14.10.1006.1001
E: Couldn't find any package by regex 'fglrx-14.10.1006.1001'
I am trying to completely remove the last remnants of the current ATI/AMD FGLRX driver I downloaded from them. When I run the above command, I get the above output. How can I remove this entry from DKMS?
Buford T. Justice
  • 1,590
  • 14
Not sure that is what's causing the problem here, but you probably don't mean to have the pattern expanded by the shell, so you should quote it:
If you have a file fglrx-14.10.1006.1001 in the current directory,
the command
gets expanded to
sudo apt-get remove --purge fglrx-14.10.1006.1001
which would explain why apt-get is looking for that package.
Quote the pattern like this to prevent the shell interpreting the *:
sudo apt-get remove --purge "fglrx*"
Volker Siegel
  • 13,295
