running: Kubuntu 11.04x64
Both programs quit right after being launched and I get the following errors when running each applications from the terminal:
OpenShot:
   OpenShot (version 1.3.0)
Process no longer exists: 5485.  Creating new pid lock file.
state saved
The program 'openshot' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadMatch (invalid parameter attributes)'.
  (Details: serial 25 error_code 8 request_code 132 minor_code 19)
  (Note to programmers: normally, X errors are reported asynchronously;
   that is, you will receive the error a while after causing it.
   To debug your program, run it with the --sync command line
   option to change this behavior. You can then get a meaningful
   backtrace from your debugger if you break on the gdk_x_error() function.)
QBitTorrent:
qbittorrent: symbol lookup error: qbittorrent: undefined symbol: _ZN10libtorrent7sessionC1ERKNS_11fingerprintEii
EDIT (7.13.11):
I removed qbittorent from my computer:
sudo aptitude purge qbittorrent
I removed the GetDeb repository from my sources.list file (actually just commented them out), updated my database and reinstalled qbittorrent:
sudo aptitude install qbittorrent
Don't know why but this application seems to launch properly, with the exact same versions of QBitTorrent (v2.8.2-0) and LibTorrent-RasterBar6 (v0.15.6) as before.
Still have the problem with OpenShot Video Editor, so could really use help with that if anyone has any ideas as to what the problem is. Thank You.
13east
  • 1,945
Update qbittorrent from PPA. or downgrade, if tou use ppa. it's all because of libtorrent-rasterbar6 update. downgrade this package, or upgrade qbittorrent from ppa
The kind of error you experience at qbittorrent usually happens when qbittorrent is built against one version of libtorrent and executed against another. Could you please check you system to make sure you don't have several versions installed ? like for example one in /usr/lib and one in /usr/local/lib?
