So I'm trying to get RVM setup on Lubuntu using instructions here. They say to change my shell settings, but the UI of Lubuntu / LXTerminal doesn't have that option (as far as I could see). If I try to go without it, I get errors later on, saying pretty much the same thing. If I try to look up help, it says pretty much the same thing. What should I do?
Roman Davis
  • 33
According to man lxterminal:
-l --loginshell
       Executes login shell.
You have to start the terminal manually with the -l option.
But that is pointless, since you can always run a login shell easily using:
bash -l
from a terminal which is not running a login shell. So everytime you open a new shell while installing, start a login shell using bash -l. This is only needed until you logout or restart.
muru
  • 207,228
