I am trying to install Ubuntu alongside windows and it won't work. I go through the installation process and it says to remove installation media and close tray. Then press enter. When I do this the computer restarts like normal and then boots to windows!
most ppl are smarter than me. But this is how I did it: log in in windows. go to unetbootin.sourceforge.net download GParted, while you are at unetbootin, make a bootable cd, or usb (of 4 gb size at least) with Ubuntu 14.04 on it, then go back to windows desktop. take out cd, or usb and set it down beside you. start GParted, and make a seperate partition for ubuntu. I split my HDD 50/50. when you are done with the partitions, close all programs, and then shut down computer. insert cd, or usb and restart computer (be sure to enable boot from cd or usb in bios) press F12 or F2 when given the option. if you did things right, you should boot from cd, or usb. you will then be able to install ubuntu onto the new partition on your HDD, from the cd or usb. There are great articles on how to use GParted on the web or at unetbootin... I printed the article called "Using GParted" that is at unetbootin. it has screen shots and step by step instructions, to help get you up and running in no time. using_gparted.txt by patrick. take my advice and learn all you can about GParted FIRST... and have fun
- 1
- 1
