I have here an Asus Eee pc, model is the 1005peb version. Now for the most part it runs fairly decent and quick, not much issue with it except one major one.
Every time I restart or turn on the netbook my brightness is set to full yet my screen is like almost full on black, like it's turned off. I turn down the brightness a couple times using the Fn + F5/F6 keys and it goes nice and bright etc. When I turn the netbook on I have to turn down my brightness level to see the screen at what (I think) is full brightness and it's then ok. If I turn it off and restart etc I have to do it all over again.
Down is up kinda thing...it's an odd and annoying issue, one that I cannot find an answer for anywhere. So if anyone has a solid way of getting it fixed I would be most appreciative. Thanks!
  • I'm using Ubuntu 11.04, Desktop Edition, Standard Grub settings and Kernel no changes to any of the hardcore system settings...
  • I tried Ilari Kajaste's suggestion and it had no effect. Neither better nor worse.
  • @fossfreedom I'll look deeper into your suggestion but at this time it looks almost the same as the second answer so I doubt it is what I currently seek.
Jorge Castro
  • 73,717
zkriesse
  • 1,425
5 Answers5
I had the same problem with my Asus Eee PC 1001PX. The solution was to add acpi_osi=Linux to the computer bootup kernel options.
The bootup kernel options are controlled by the GRUB boot loader. You need to edit the grub settings at /etc/default/grub to have the following line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet acpi_osi=Linux splash"
After editing the file, you need to make sure you run update-grub for your edit to take effect.
Hopefully this same solution works for you. If it doesn't, you can also try adding the option acpi_backlight=vendor to the same line which was also suggested to me when I tried to get the issue fixed.
zkriesse
  • 1,425
Some BIOS's are buggy - for example, this bug-report mentions that a recent BIOS revision fixed brightness issues (revision 1202). Suggest check the vendor website and install the latest available BIOS revision.
Even with a BIOS update, it is worth checking whether the standard eepc grub options still apply to your model
Try adding either acpi_osi=Linux source or
acpi_osi=Linux acpi_backlight=vendor source
i.e.
gksu gedit /etc/default/grub
add to the values above to GRUB_CMDLINE_LINUX_DEFAULT
save
sudo update-grub
What you have described may point to general power-management issues.
Have you installed the jupiter_0.0.50.2_all.deb package on sourceforge? More information about this can be found on WebUp8.
fossfreedom
  • 174,526
Update for 13.10, kernel 3.11.0-19-generic, 32bit.
I have a 1005PE:
    Manufacturer: ASUSTeK Computer INC.
    Product Name: 1005PE
    Wake-up Type: Power Switch
    SKU Number: 1005PE
    Family: Eee PC
with BIOS:
BIOS Information
    Vendor: American Megatrends Inc.
    Version: 1202
and it works without any kernel command line parameters
[:~] % cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-3.11.0-19-generic root=[...] ro persistent quiet splash vt.handoff=7
(I do not know what persistent do --- maybe a remnant of some old test).
I do have a couple of drivers running, but they are doing that automatically --- they are loaded by the kernel without further help:
85% [:~] % lsmod | egrep -i "eee|asus"
eeepc_wmi              12983  0
asus_wmi               23495  1 eeepc_wmi
sparse_keymap          13708  1 asus_wmi
video                  18777  2 i915,asus_wmi
wmi                    18590  1 asus_wmi
The laptop works ok (although better with xubuntu than the full fledged version); backlight, sound, suspend --- all the hw is working flawlessly.
Rmano
  • 32,167
What do your settings tell you in /etc/laptop-mode/conf.d/lcd-brightness.conf
The lcd-brightness module allows you to control the brightness of your LCD screen.
   CONTROL_BRIGHTNESS
             When this option is enabled, laptop mode will adjust your LCD
             screen’s brightness settings, if possible. You must configure
             the following settings for this to work.
   BATT_BRIGHTNESS_COMMAND
   LM_AC_BRIGHTNESS_COMMAND
   NOLM_AC_BRIGHTNESS_COMMAND
   BRIGHTNESS_OUTPUT
             The  BRIGHTNESS_COMMAND settings specify commands that should
             be executed in order to set the brightness of your  LCD.  The
             BRIGHTNESS_OUTPUT  setting  specifies where the output of the
             command  will  be  written.  For  instance,  if  your   LCD’s
             brightness is adjusted by writing a numeric value 3 to a file
             called /proc/brightness, you should set the command to  "echo
             3"  and  the output file to "/proc/brightness". If your LCD’s
             brightness is adjusted using a utility  like  "toshset",  you
             should  include  the  entire  toshset  command  line  as  the
             command, and set the output file to "/dev/null".
wojox
  • 11,840
it'a one abnormal behaviour on asus eeepc notebook with Fn brightness keys on ubuntu 14.04. when you press Fn+F5, or Fn+F6 keys to change brightness, brightness jumps almost twice. it's said about, it's a matter of performing brightness change action first by acpi and after that by Xserver, so the result is, brightness changes faster, in larger steps than you like or expect. for me have worked one slighlty different solution, change line at /etc/default/grub as many authors suggest, but insted of acpi_backlight=vendor use acpi_backlight=off use as well acpi_osi=Linux otherwise brightness change will not works totally.
There's no need to install laptop-mode-tools or other packages... but this will cause, brightness change information slider doesn't appear as before (Xserver action is not performed), but brightness changes in normal, BIOS supported steps, it seems to me it's 10 steps at asus eeepc. maybe this can be solution on more problems you've posted.
αғsнιη
  • 36,350
1 618
