I am using ubuntu 14.04 on ec2 instance, I am changing dhcp settings as part of the provisioning process, and I cant find a way to reload the dhclient. Infact, theres no way to restart network on 14.04 cloud instances. Any suggestions?
Asked
Active
Viewed 5.1k times
13
The -r flag explicitly releases the current lease, and once the lease has been released, the client exits. Open a terminal and type the command:
$ sudo dhclient -r
Now obtain fresh IP:
$ sudo dhclient
Jan
- 12,931
- 3
- 34
- 39
Typically I do this by running dhclient as a single command like so:
$ sudo -Es
$ dhclient -r; dhclient
You can use this trick if you've made changes to /etc/dhcp/dhclient.conf:
$ cat /etc/dhcp/dhclient.conf
timeout 300;
retry 60;
supersede domain-search "dom1.mydom.com", "dom2.mydom.com";
prepend domain-name-servers 192.168.7.185,192.168.7.186;
References
slm
- 3,155
Yeah... no. dhclient -x or dhclient -r didn't work for me. What did work was
sudo su
ps fax
then copy the entire command-line that starts with /sbin/dhclient, including all the command-line options, file paths, etc...
Then
pkill dhclient
and paste the command-line from ps fax into your terminal and hit enter.
Mr Stock
- 21
- 1
