I am trying to compile paragon ntfs driver http://www.paragon-software.com/home/ntfs-linux-per/screenshots.html and got “no symbol version for module_layout" error when modprobe loading modules. According to answer "no symbol version for module_layout" when trying to load usbhid.ko I should have the same versions of linux-source, linux-headers and running kernel. I have Ubuntu server 14.04 LTS uname -r 3.8.0-44-generic, but no linux-source-3.8.0-44 and linux-headers-3.8.0-44 in repositary.
Where i can got linux-source-3.8.0-44 and linux-headers-3.8.0-44? Thanks Konstantin
You can install this from the precise repo, 3.8 was the default kernel on 12.04.
You're on 14.04, thus your sources.lst points towards trusty:
Either download the packages from here and install then using dpkg -i <pkgname> http://packages.ubuntu.com/precise/linux-headers-3.8.0-44
http://packages.ubuntu.com/precise/linux-headers-3.8.0-44-generic
or add the old repo to your sources.lst and install from there.
Searching on http://packages.ubuntu.com doesn't yield results for linux-source... though.
Jan
  • 12,931
  • 34
  • 39
