I want to make a bash script that clears the history i.e. works similarly as the command
history -c
So I started with the following code:-
#!/bin/bash
history     #displaying history
history -c  #clearing history
None of them worked. On some searching around, I came to know that bash disables history in non-interactive shells by default, but we can turn it on. So after editing I tried the following code :-
#!/bin/bash
HISTFILE=~/.bash_history   # Or wherever you bash history file lives
set -o history             # enable history
history
history -c
It shows the output :-
[root@localhost lib]# bash a.sh
1  history
And besides that the hisory -c command did not work. Because I am still getting the history of commands when I type history. This means both history and history -c didnt work inside the bash script.
How should we use it then?
EDIT 1- I want to delete the history of the current session, it must be stored somewhere. I have tried using commands like the following but to no effect:-
cat /dev/null > ~/.bash_history && history -c && exit
P.S.-This is not a duplicate question. Please try to understand the difference before marking it as duplicate. I want to clear the history of the current session through a script . I don't care if it is written back or whatever. The other question is about to permanently delete the history. It has nothing to do with the script or through other terminal.
You can't delete history like this as it will delete the history of current session.
If you wan to clear your history using script use following command in your script
> ~/.bash_history
It is enough to clear all your bash history .
g_p
  • 19,034
  • 59
  • 69
I think that
history -c
will only clear the history inside the seesion associated with the script This example:
#!/bin/bash
uname -a > /dev/null
history
history -c
history
shows the output:
500  history
501  uname -a > /dev/null
502  history
4  history
which is what one expects.
If you want to erase the history, try
> $HISTFILE
Gremlin
  • 747
  • 18
