I need to update my Ralink 5390 adapter driver and I don't know what the terminal command is. I've searched all over the net for it and I have found nothing. My wifi driver needs to be updated badly so I would like to update that first. It is a Ralink 5390 adapter on a Compaq Presario CQ57 Laptop. Any help is appreciated, Thanks. I am currently running Ubuntu 14.04
In Linux, most drivers (the ones that are open source) come with the kernel; so the packages that contains the driver are linux-image-generic and (possibly) linux-firmware (1).
You can check if it is up-to-date with
apt-cache policy linux-image-generic
apt-cache policy linux-firmware
and updates should be automatic --- if not, the classical old sudo apt-get update; sudo apt-get dist-upgrade should work.
Notice that sometime there is a problem in upgrades that makes that the old kernel is retained; in that case use
apt-get install linux-generic
to update the kernel/firmware to the last available for your distribution.
If the device has a not open-source or a driver which is not in the official kernel, things are different, and are very device-dependent.
Footnotes:
(1) normal kernels. change -generic with -rt or -lowlatency if you have some fancy (audio workstation, real time) configuration.
Usually to upgrade your software and drivers on your system, the general method followed is
$ sudo apt-get update
$ sudo apt-get upgrade
Comment down if the problem still exists.
- 2,303
