I have been having a weird wifi card issue.
First, the hardware details from lshw:
  • product: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
  • wifi card: Intel(R) Centrino(R) Wireless-N + WiMAX 6150
  • computer maker: Asus
I have a Wireless router which other computers can easily connect to. The router has WPA personal security on it. When I was bringing up the computer on Ubuntu 14.04 LTS, here's what I have observed in /var/log/syslog.
Can I do something without the card replacement? Or am I out of luck?
Update: I tried the suggesting given by @karel. Some more info on the wireless card now being identified properly $> lshw -c network
*-network
   description: Wireless interface
   product: Centrino Wireless-N + WiMAX 6150
   vendor: Intel Corporation
   physical id: 0
   bus info: pci@0000:02:00.0
   logical name: wlan0
   version: 67
   serial: 40:25:c2:c2:4b:c0
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress cap_list ethernet physical wireless
   configuration: broadcast=yes driver=iwlwifi driverversion=3.13.0-24-generic firmware=41.28.5.1 build 33926 ip=192.168.0.111 latency=0 link=no multicast=yes wireless=IEEE 802.11bg
   resources: irq:51 memory:de800000-de801fff
Update 1: $> iwconfig
wmx0      no wireless extensions.
eth0      no wireless extensions.
lo        no wireless extensions.
wlan0     IEEE 802.11bg  ESSID:off/any
      Mode:Managed  Access Point: Not-Associated   Tx-Power=15 dBm
      Retry  long limit:7   RTS thr:off   Fragment thr:off
      Encryption key:off
      Power Management:off
Update 2: I did:
  • modprobe -r iwlwifi
  • modprobe iwlwifi
and then observed this log in /var/log/syslog.
Update 3:
modinfo iwlwifi is here. I did an rmmod on iwldvm and then modprobe iwldvm.
It's not yet clear what fixed my problem but it seems to work. There are a bunch of things that appear to have to come together for it to work well. I am somewhat puzzled why this has to be this hard.
  • It seems that having options iwlwifi 11n_disable=1 in /etc/modprobe.d/iwlwifi helps.
  • Suggestions in this thread seem to help, given that we started having these issues since Trusty.
  • Experimenting with country regulatory domain (as explained here) seems to have helped.
  • I also tried with a few kernels, not sure if that helped. Right now, I am using the kernel that Trusty comes with (3.14.1-031401-generic)
All of this is empirical, as you can see. But it seems to help. I am updating this answer using the same wireless card that was not working at all.
