First time posting here for help.
So Friday night I was playing around with GParted and accidentally deleted several partitions. One of the was an unnamed. After doing this, I restarted and I was greeted with the "Reboot and select proper boot device".
Knowing I had screwed up, I looked up the problem and arrived to the conclusion that I had nuked the EFI partition that basically held the boot loader. One of the proposed ways to fix it was to use the Windows Boot Repair option for an installation disk. This morning I tried that option and it worked! I can now boot into Windows.
After doing that, I booted into a live CD and I tried to reinstall GRUB2 via the Boot Repair guide over at https://help.ubuntu.com/community/Boot-Repair This is where my problem begins. I can't seem to get GRUB to show up as my default bootloader. Here is the pastebin log from that: http://paste.ubuntu.com/8345872/
I followed another guide that said I needed to point at the bootloader from within Windows by using
bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
But even this doesn't seem to work as I am greeted with the following:
C:\WINDOWS\system32>bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
The parameter is incorrect.
Running bcdedit by itself returns the following:
Windows Boot Manager
identifier              {bootmgr}
path                    \EFI\Microsoft\Boot\bootmgfw.efi
description             Windows Boot Manager
locale                  en-US
inherit                 {globalsettings}
integrityservices       Enable
default                 {current}
resumeobject            {cbbe29da-23e7-11e4-9d02-bbb0e4fcb58b}
displayorder            {current}
toolsdisplayorder       {memdiag}
timeout                 30
Windows Boot Loader
identifier              {current}
device                  partition=C:
path                    \WINDOWS\system32\winload.efi
description             Windows 8.1
locale                  en-US
inherit                 {bootloadersettings}
recoverysequence        {cbbe29d8-23e7-11e4-9d02-bbb0e4fcb58b}
recoveryenabled         Yes
isolatedcontext         Yes
allowedinmemorysettings 0x15000075
osdevice                partition=C:
systemroot              \WINDOWS
nx                      OptIn
bootmenupolicy          Standard
I am at a loss of how I could get around this issue, but more importantly, how I can get GRUB2 as my bootloader so I can get into Ubuntu Partition. Any help is appreciated. Thank you for your time.
ADDITIONAL INFO
Running the command efibootmgr -v yields me the following,
BootCurrent: 0005
Timeout: 1 seconds
BootOrder: 0004,2003,2001,2002
Boot0000* Windows Boot Manager    HD(4,96800,32000,d5769c5b-3c38-11e4-9237-c832b0e56206)File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...\................
Boot0001* UEFI: Network Card     ACPI(a0341d0,0)PCI(1c,3)PCI(0,0)MAC(202564958e96,0)IPv4(0.0.0.0:0<->0.0.0.0:0,0, 0..BO
Boot0002* UEFI: Network Card     ACPI(a0341d0,0)PCI(1c,3)PCI(0,0)MAC(202564958e96,0)030d3c000000000000000000000000000000000000000000000000000000000000000000000000000000004000000000000000000000000000000000..BO
Boot0003* UEFI: M4-CT256M4SSD2    ACPI(a0341d0,0)PCI(1f,2)03120a000400ffff0000HD(1,96800,32000,d5769c5b-3c38-11e4-9237-c832b0e56206)..BO
Boot0004* ubuntu    HD(1,96800,32000,d5769c5b-3c38-11e4-9237-c832b0e56206)File(\EFI\ubuntu\grubx64.efi)
Boot0005* UEFI: TSSTcorp CDDVDW SU-208FB    ACPI(a0341d0,0)PCI(1f,2)03120a000500ffff0000CD-ROM(1,76991,1240)..BO
Boot2001* EFI USB Device    RC
Boot2002* EFI DVD/CDROM    RC
Boot2003* EFI Network    RC
FDisk returns:
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 256.1 GB, 256060514304 bytes
255 heads, 63 sectors/track, 31130 cylinders, total 500118192 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xd4a6f69c
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1               1   500118191   250059095+  ee  GPT
I ran GDisk and it returned me this:
GPT fdisk (gdisk) version 0.8.8
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/sda: 500118192 sectors, 238.5 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 5657A54D-73E9-4B33-8700-A8E287822B16
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 500118158
Partitions will be aligned on 2048-sector boundaries
Total free space is 879213 sectors (429.3 MiB)
Number  Start (sector)    End (sector)  Size       Code  Name
   1          616448          821247   100.0 MiB   EF00
   2         1083392       395257855   188.0 GiB   0700  Basic data partition
   3       395257856       500117503   50.0 GiB    8300
The third partition is where Ubuntu is installed. The 100MB partition is the EFI partition created by the Windows Start-Up Repair and the second one is the Windows 8.1 partition.
subseven
Test this:
Boot into a live Dvd/Usb Ubuntu 64 bit
Open a terminal.
Run it:
sudo -i
mount /dev/sda3 /mnt
mount /dev/sda1 /mnt/boot/efi
mount --bind /dev /mnt/dev
mount --bind /dev/pts /mnt/dev/pts
mount --bind /proc /mnt/proc
mount --bind /sys /mnt/sys
modprobe efivars
chroot /mnt
apt-get install --reinstall grub-efi-amd64
update-grub
umount /mnt/boot/efi
umount /mnt
reboot
kyodake
  • 17,808
It should be possible to repair GRUB, however I suggest to try rEFInd because it's very easy to use.
rEFInd automatically finds operating systems on internal and external drives, and should not need configuration at all (but it can be configured for particular circumstances).
It can be installed from Windows and also from the live environment.
Installing from the live environment
You should mount the efi partition as /boot/efi. To do this, run:
sudo mkdir -p /boot/efi
sudo mount /dev/sdXN /boot/efi
You need to place the right device letter instead of X and the right partition number instead of N. After that, you can add a PPA and download a DEB file which will automatically copy rEFInd in the right place during the installation.
sudo apt-add-repository ppa:rodsmith/refind
sudo apt-get update
apt-get install refind
After rebooting, you should be able to select which OS you want to run, without any further configuration.
Installing from Windows
Installing manually from Windows takes a bit longer. The step-by-step process is described here.
