Wifi worked fine on my dell inspiron e1505 with broadcom 4311 wifi.
Since upgrading to 14.04, wifi does not work after resuming from (close-the-lid) suspend. If I then manually put it in suspend again with the keyboard, wifi works on resume ~95% of the time.
output from lspci and lshw follows.
lspci | grep -i network 0b:00.0 Network controller: Broadcom Corporation BCM4311 802.11b/g WLAN (rev 01)
lshw *-network description: Network controller product: BCM4311 802.11b/g WLAN
vendor: Broadcom Corporation physical id: 0 bus info: pci@0000:0b:00.0 version: 01 width: 32 bits clock: 33MHz capabilities: pm msi pciexpress bus_master cap_list configuration: driver=b43-pci-bridge latency=0 resources: irq:16 memory:efdfc000-efdfffff *-network description: Ethernet interface product: BCM4401-B0 100Base-TX vendor: Broadcom Corporation physical id: 0 bus info: pci@0000:03:00.0 logical name: eth0 version: 02 serial: 00:15:c5:a5:9d:b0 size: 10Mbit/s capacity: 100Mbit/s width: 32 bits clock: 33MHz capabilities: pm bus_master >cap_list ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=b44 driverversion=2.0 >duplex=half latency=64 link=no multicast=yes port=twisted pair speed=10Mbit/s resources: irq:17 memory:ef9fe000-ef9fffff*-network description: Wireless interface physical id: 2 logical name: wlan1 serial: 00:16:cf:17:a4:4f capabilities: ethernet physical wireless configuration: broadcast=yes driver=b43 driverversion=3.13.0-35-generic >firmware=666.2 ip=192.168.1.103 link=yes multicast=yes wireless=IEEE 802.11bg>
