-1
I bought a new Lenovo B350 with Windows 8 pre-installed. Should I continue with the windows setup and then just download 14.04 from the Ubuntu website? I tried just booting a 14.04 DVD and it did not install. The computer remained on the acceptance of Windows window.
Braiam
  • 69,112
Do you mean it ignored the dvd and booted into windows instead? If that is what happened you need to change the boot order in your bios to boot from cd before the hard drive
John
Editing and viewing the bios is easy. When your computer boots the first screen you see will have the option to go to bios menu. It's one of the f-keys. You may have to restart a couple times cause the screen doesnt stay very long. In the menu you should see the boot order and be able to change it if it isnt already set to boot from cd/dvd drive first. This wont stop it from booting normally if you dont have a cd in the drive. When it boots from the cd you will be given the option to run it live or install. I would recommend trying it live first
John
Most unfortunately I believe you will need to finish the installation of Windows first - the pre-installed system has not done it's final configurations yet, and it will be difficult to utilize the computer until this is complete.
The exception to this would be if you decide to dump Windows entirely - if you have Ubuntu downloaded from another computer, you could boot to the CD / USB and format the HDD, which would bypass the Windows configuration.
Charles Green
  • 21,859
