I have an .sh file that looks like
#!bin/bash
exec /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/
java java -jar /home/me/myfolder/my.jar
I've made this file executable and it works fine when in the "nautilus" desktop, but when I run it on just normal desktop (Ubuntu 14.04) it only opens with gedit. I have also tried opening it with Java 7 and Java 6, but it does not give me the option to run in terminal. Also when i'm in the terminal and cd to the folder containing the .jar file and run it that also works fine. What I'm looking for is a way to just double click my .sh file without having to go to nautilus first. Is this possible?
Sorry if this is a duplicate, but I cant find the answer I'm looking for.
Jacob Vlijm
  • 85,475
When you have made it executable with chmod +x file/name.sh, you can run it by typing ./file/name.sh in terminal.
Edit: Actually just read what you where trying to do. Try commenting out the "exec" line of the script, and change the second line to ./home/me/myfolder/my.jar after you have run chmod +x /home/me/myfolder/my.jar.
I don't know much about java, but I have run some java programs like this.
You can create a desktop file and make it executable, then run it from nautilus or desktop directly. Here is an example:
Create a file using:
gedit myjar.desktop
Copy and paste the code below:
#!/usr/bin/env xdg-open
[Desktop Entry]
Version=1.0
Type=Application
Terminal=false
Exec=java -jar my.jar
Name=My Java Gui
Icon=/usr/share/icons/hicolor/48x48/apps/openjdk-7.png
#Path=/$HOME/
Some entries like path are optional.
Make it executable:
chmod +x myjar.desktop
Run it from nautilus.
Harris
  • 2,588
